Troll Hunter
Update on wipers. I pulled the gauges and gave the mechanism a tap. Got them going. Lubed them up and they were fine....until the next day. Went on once and then wouldn't go on again. What's going on?
This post was auto-generated based upon a question asked on our tech article page here:
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-02-2013, 01:00 PM
Nick at Pelican Parts's Avatar
It's possible you have short circuit, an open wire or a bad connection. I would trace the wiper circuit with a wiring diagram, check for open / corroed wires or loose connections.
- Nick
Troll Hunter
Yeah, no. I retested everything. 12.5 volts at the plug. Motor runs occasionally, and well. When I turn it off, sometimes it turns back on, other times not. When it won't start, a tap with a long screwdriver against the mechanism gets it going every time. Someone posted 'bad commutator', and I'm beginning to think he's right, even though I didn't know what a commutator was yesterday.
Whaddaya think?
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-02-2013, 01:43 PM
Troll Hunter
Replaced the motor with a used motor. Bingo.
Not easy to do. Have to pull gauges to get access, plus all frunk junk like cover, fresh air blower, plenum, defrost plenum etc to get access as well.
Might as well reverse wipers while you're doing that, and lube all moving parts of HVAC system.
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-08-2013, 11:55 AM
