'77 915 tranny.
Bentley's says 18 ft/lbs, I am paranoid that this is an error. Does any one have this spec?? Thanks in advance.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
18 lbs? that sounds finger tight.
2000 MR2 spyder 2001 ford Escape |
Those are DIN 8.8 M8 bolts, and 18 lb-ft is the 'standard' torque ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks Warren . . . paranoia has been relieved
Navin Johnson
torque is sometimes greatly misunderstood, 18 ft/lbs sounds like "to little" torque. We measure torque in Lb/ft or Ft lbs etc......
so 18 ft/ lbs would be applying 18 lbs of force at 1 foot from a fulcrum.. Torque is a value in motion a significant amount of tension can generated with a small diameter bolt. fine threads, lubricated etc...... torque values are usually well out of the plastic range of the material the bolt is made of... allowing for thermal factors etc..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Oh - oh ... don't tell me you are starting to get paranoid now too!
Doug '81 SC Coupe |
