-   -   gearbox output flange weldable? (http://forums.pelicanparts.com/porsche-911-technical-forum/769241-gearbox-output-flange-weldable.html)
safe 09-03-2013 04:39 AM
I'm installing a 78 915 box in my 69 tub.
The original driveshafts and CVs from my 69 are good, strong and usable. The 79 CVs less so.
I would like to use the older 108mm CVs, but finding a garbox output shaft with 108mm flange that fit my gearbox is nearly impossible or maybe not possible at all....
Could I have my machinist make a 108 mm flange and weld that to my 100 mm flange?
I don't think it would matter if I add a 10 mm thick flange, since the original 901 gearbox was wider than the 915 box
But, are these cast parts reliably weldable?
Left -79 100mm, right a -75 108 mm
http://i1037.photobucket.com/albums/...ps97e3bcd4.jpg
haasad 09-03-2013 04:44 AM
Definitley, I converted a set of coarse spline and fine spline output flanges with careful machining and high quality welding. They have handled 1200 miles on my
200 wheel HP motor no issues.
Andy
safe 09-03-2013 04:51 AM
Andy
I thought I seen a thread about it but forgot where (on DDK maybe?) was that your?
You don't have any pictures on how you did it?
haasad 09-03-2013 11:45 PM
Hi yes it was on my r car thread ddk. I will try to dig out any puictures but they are on line.
Andy
safe 09-04-2013 02:50 AM
Found it!
DDK - Die Deutschen Klassiker • View topic - 915 gear box drive flanges
I was thinking of doing it like that, but thought the weld might be to weak. Therefore my suggestion above adding a new flange to existing and thereby having a longer weld.
Maybe you are right and it will hold just fine!
I'm going to use a ~300 hp 3.6 engine.
chris_seven 09-04-2013 04:18 AM
It is always a concern to weld parts of this type without considering the detailed metallurgy and the position of the weld.
The failure of this type of component is concerned with probability.
The first question would be what is the probability of finding a defect in the weld and the second is what is the probability that this defect will propagate.
In this case the weld line corresponds to the position of maximum stress and some basic stress analysis wouldn't be a bad thing.
In the '20 Golden Rules' for the avoidance of fatigue I would try to avoid welds placed at the point of maximum stress.
Some idea of the material's composition would also help as then you could decide on the likely condition of the Heat Affected Zone and the resulting microstructure.
I guess the last question is the risk assessment in terms of failure.
If the flange breaks will the drive shaft damage the rear seat pan and any (unlikely) passenger.
It is unlikely to be 'weak' in the traditional sense but it may well be brittle.
I would worry that the probability of finding crack like defects in this type of weld could be quite high and if the material has a carbon equivalent of 0.4 or higher then its HAZ structure will probably allow any defect to propagate.
If the steel used is low in carbon and alloy content then it may not be an issue but I would like to know.
The last thing to worry about the impact of any failure. If the flange breaks will the drive shaft damage the floor pan and how badly. :)
safe 09-04-2013 05:45 AM
Thanks for your insight.
I think I'll try weld it at a different location, but on the other hand it has worked well for Andy.
I can probably get the welds x-rayed, the neighbors to my garage is in that business.
KTL 09-04-2013 07:05 AM
What about having your machinist make an adapter from 100 to 108? But that would involve custom axles.....
I know you can also use a G50 axle flange. Rothsport modifies them in a way to fit the 915. Here's a pair that William Knight was selling
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/671885-108mm-output-flanges-915-fine-spline.html
For others considering this in the reverse fashion (need a 108mm coarse spline flange to fit larger modern 108mm CVs) Albins makes a coarse spline axle flange. But I do not know what diameter it is. I would hope it is 108mm simply because I would guess they'd design it to fit the 930 or 934 CVs they also make?
You could also swap out your diff in the 915 for a coarse spline diff.
See page 5 for product "Porsche Components 915 Output Flange Coarse Spline LSD" http://www.albinsgear.com.au/productcatalogue.pdf
Matt Monson 09-04-2013 09:58 AM
I manufacture 108mm fine spline stubs. But if you have to ask how much they cost, they are probably more than you are willing to spend.
KTL 09-04-2013 10:38 AM
Doh, didn't know that. Good to know. Hows abouts coarse splined 108s to accept the newer style "capped" CV joints?
I've currently got an old set of 108 coarse splines on the bench (just like the ones pictured above) I was going to fiddle with and see what kind of work is needed to make them work for me with the newer G50 style axles. But I don't like how the old flanges are not as robust/thick as the newer flanges.
chris_seven 09-04-2013 10:53 AM
I think that it may be difficult to weld at a different location and although it appears to have worked well so far we need to bear in mind that metal fatigue is an insidious process.
Damage accumulates over relatively long periods of time - and can be assisted by corrosion - before defects propagate in an unstable manner and a brittle fracture event occurs - normally with no prior warning.
Fatigue in one form or another is probably responsible for at least 90% of all engineering failures so needs to be considered.
1200 miles is not really much of a test and the SAE usually suggest this type of component should achieve a Weibull B10 life at a 50% confidence level and a significant amount of test data would be needed to 'prove' this method of manufacture.
Making one-off parts is risky and doesn't take any statistical or stochastic models into account and it is possible that the third shaft made using exactly the same methods could fail in a few minutes.
X rays are good and will find macroscopic defects but there may be some small defects that can propagate in brittle materials that could be difficult to find using this type of technique.
welding defects
Can your colleagues next door analyse the material as this may help to define the depth of the problem?
I do accept that I may be overcautious but the problem with using TIG welding for this type of components is the variability.
I would almost certainly buy new parts.
The $320 on the Albins Price List doesn't seem a bad price but I would make some locally as they are relatively straightforward.
safe 09-04-2013 12:36 PM
welding defects
The $320 on the Albins Price List doesn't but I would make some locally as they are relatively straightforward.
I was thinking of making a "ring" drill and tap, then weld that to the existing flange. Then the weld would be in a less stressed location and I would get at least double the amount of weld.
Not sure if the guys can analyse the material.
I'm aware that it's sort of a gamble...
ClickClickBoom 09-04-2013 04:59 PM
Not to be a fly in the ointment, I doubt the those axles are cast. As a seat of the pants non-engineer, that application would indicate something forged and machined to spec. The real problem is with the fatigue and stress analysis, or lack there of. Welding and the resultant HAZ will introduce a whole 'nuther set of variables that most aren't able to answer. The question is why would Matt make a solution to the problem if simply welding and machining would suffice?
And the $96,000 question, if the axle breaks at a most inopportune moment, say in a 3rd gear, 6000 RPM sweeper what will happen, other than the the valves meeting the pistons in a most inappropriate fashion. Not to mention what will happen to the car.
The next big question is how much will any of the above cost to fix if the failure occurs, bet Matt's axles seem cheap now....
lrodri64 09-04-2013 07:58 PM
Just a suggestion....
Why not change also the differential spider gears?
safe 09-05-2013 12:12 AM
It's an option, maybe. I would probably need to change the whole diff.
Could anyone confirm that the right stub axle in the picture would fit an earlier 915 course spline diff?
As you see its not only the spline that is different....
Shaun @ Tru6 09-05-2013 05:22 AM
Can you explain why pistons will hit valves if an axle breaks.
Fishcop 09-05-2013 05:36 AM
Magnus, having done a similar conversion to a 915 in a 69 chassis; I have to ask what you'll be running that a set of SC axles/CVs can't cope with? For me it was infinitely easier to change the stub-axles in the trailing arms than changing gearbox internals or 'customising' drive shafts... If it's a cost thing, it may be false economy. Sell/swap the early driveshafts for good SC versions.
safe 09-05-2013 05:59 AM
Nothing special, a mostly stock 3.6.
But I have a nice set of drive shafts from the 69, that's among the strongest CVs Porsche did (according to Grady). The 100mm CVs are a bit on the weak side.
New SC drivshafts is ~$240 each, but the outer stub axles is $530. That's way more than I'd like to spend on this...
Haven't found any good used complete axles yet. I would consider that.
ClickClickBoom 09-05-2013 06:05 AM
The flange, if it were to fail would most likely be under load, 6000RPM means a foot full of gas, any sudden decrease in loading while under that amount of power would cause the engine to accelerate instantly, into an over rev situation, enough over rev will cause valve float.
Fishcop 09-05-2013 06:11 AM
Fair enough.
I located the stub-axles second hand for $100 each and cleaned up a second hand pair of shafts with new grease and boots (and a bit of paint) for $150 each. But I'm only running a 2.7 engine.
Good luck with the conversion.
KTL 09-05-2013 07:16 AM
You should be able to find a set of outer 100mm stub axles quite easily. They are very plentiful on the used market. I don't think the 100mm CVs are necessarily the weak link. It's the M8 bolts and their relatively low torque that often loosens the connection. That said, with proper attention they should hold up OK. Our old MotoDelta 1970 911 GTS4 car had a 248RWHP 3.3L short stroke in it and used the SC axles for a number of years before eventually switching to a G50 (problematic 915 had to finally be abandoned) and in that time the car never had a problem with axle failure. Low ride height, sticky radial slicks and fast = a lot of load put thru those 100mm CV axles every time it hit the track. Never had an axle fail in ~7 years of running those axles. Key was ensuring the bolts were tight during regular nut & bolt check plus annual regreasing.
That said, a 3.6L is a torquier engine and the car you're running is considerably heavier than our old 1970 car. 108mm axles are not a bad idea for a 3.6 car considering that's how the factory 3.6 cars are equipped by Porsche
Shaun @ Tru6 09-05-2013 07:17 AM
That's funny.:D
356RS 09-05-2013 08:48 AM
I had a set of 68 stub axles on the 68 IRS arm modified to accept 930 CV joints. This was mated to an early 915 trans. 5 years of hard driving so far.
http://forums.pelicanparts.com/uploa...1378396102.jpg
KTL 09-05-2013 11:14 AM
Mark,
Could you elaborate a bit how you modified the '68 stub axles to fit the 930 CV? Reason I ask is because I think the later CV has more articulation and that's why the later stub axles have the "reliefs" cut in them to clear the joint balls?
http://forums.pelicanparts.com/uploa...1378245556.jpg
ClickClickBoom 09-05-2013 11:18 AM
Originally Posted by Shaun 84 Targa (Post 7639646)
That's funny.:D
Not getting the funny part....unless its someone else's motorsheister motor.
356RS 09-05-2013 12:08 PM
Kevin, I used a set of early 108mm 4 bolt/2 pin stubs, cut off the CV flange section. I then cut off the 68 IRS stub axle CV section and mated the 108mm section to it. Careful measurements were made and the mating surfaces were carefully shaped before any welding was done. I had to make up a set of gaskets for the 930 CV's. On the 68 IRS arm I had to relocate the emergency brake cable hole so to clear the 930 CV.
Dodge Man 09-05-2013 01:27 PM
Check the 84-86 Carrera(coarse) hubs
69-73 have the same BC as the 84-86 Carrera & M10 bolts/thru holes. Try to buy hubs that "bolt on" because welding, stress relieving, and machining can be more costly. Hubs are machined castings and welding castings is not always easy. Since mine had the sand grain texture from the cores I called it a casting. Forged parts I have seen generally have a smooth surface from the forging die and generally do not have a sand texture on the surface. Maybe Check the splines on early 84-86 Carrera hubs and you may have what you are seeking. Check the trans info charts here on Pelican. Same axles were used from 69(901)-73(915) so you should not have length issues.
911-332-033-09-M60
Complete Axle With CV Joints And Boots (bolts not included) (2 per car, sold individually), 911 (1969-73), Each
Brand: GKN Loebro Original Equipment Manufacturer at the time of the vehicle's assembly [More Info]
I actually use the 1973 new replacement Loebro 911 axles from Pelican which are basically 84-86 Carrera replacement axles with the roll pins installed. I just knocked out the roll pins on the trans side and bolted right up. Be sure to get the factory tin grease cups for the inner CV joints to make the install a lot easier/cleaner. Gaskets are a PITA and break easily. I have a 915/72(ROW) with the fine splines and large BC. Replacement axle shaft diameter is large enough for your 300HP racing/sport purpose. Doubled the shaft OD of my 73 axles. Replacements are the same price of just 1 replacement 1973 CV joint kit. A bit of homework but worth the effort. :)
Matt Monson 09-05-2013 07:14 PM
Just a slightly off topic pet peeve but I hate when people make blanket statements about forging being better than casting. Technically, forging is a form of casting. They use dies. They cast the materials at various temperatures and in different ways. But cast doesn't mean that something is automatically done in pot metal using some rough hewn die that produces an inferior part.
Just like forging doesn't guarantee quality. A forging is only as good as the material used and the balance of the process (like heat treating or finish grinding).
Sorry, just a pet peeve of mine. Most of what we make is from billet, but that again doesn't mean that our stuff is automatically better than something forged (or cast). The Japanese are the masters of selling the merits of forged automotive parts, and some of the stuff they produce is utter junk.
chris_seven 10-01-2013 04:33 AM
How can you describe forging as a type of casting? :confused: The two processes have no similarity at all other than to produce shapes.
Forging is a 'solid' phase process and casting is a liquid phase process.
There are basic differences in resulting microstructures that will have a significant influence on mechanical properties.
This is a very basic explanation
http://www.atcgroup.com.au/CustomCastingForging/TheDifferenceBetweenCastingForging.aspx
KTL 10-01-2013 12:57 PM
Thanks for the clarification on how you did it Mark.
And Mark's not the only one to attempt this. In my hunting on VW off road sites, i've found some other welded parts
Race Ready > 930 Conversion Stub Axles
Also found in my hunting that there are virtually no VW or 914 stubs/flanges with the CV reliefs in them. So I really can't understand why Porsche chose to have their stubs relieved for clearance. Some people have said the reliefs are to allow the metal end cap to fit onto the stub. That makes sense. But recall that the smaller 100mm stubs used from 75 thru 85 have the reliefs in them and those small stubs do not use the metal end caps. They use the pesky gaskets.
yundar 10-01-2013 01:23 PM
More Questions.
Hey There... I have been reading this thread because I am replacing the CV boots on my (mostly) stock 74. Should the drive axles come off the car without having to remove the stub axles? I am able to remove them from the tranny drive flanges but they do not want to come off the stub axle side. Should I remove them as a unit with the stub axles? They are the four bolt style with retainers.
Also, can the tranny drive flanges be removed by pulling the center bolt? There is an oil leak around the drive flanges where they come out of the transmission and I would like to replace these seals. Can they be replaced by simply removing the drive flanges?
On a less technical note... I removed the Koni shocks for cleaning and I accidentally cleaned some of the paint off! Is there a close enough color or brand of spray paint that I can use to repaint them. Does Koni make or sell the paint. What do restoration people use?
Thanks, Andy.
KTL 10-02-2013 07:44 AM
Yep the axles should come off the trailing arm stubs as easily as the transmission stubs. Years of crud and dried grease most likely has them stuck on there. A good whack with a hammer and wooden dowel should knock them free. The four bolt style with the pins does a good job of holding the CV onto the stub.
Yes the trans stubs come out simply by removing the center bolt. Use a couple of old CV screws installed in the stub. Slide a bar between the screws to use as a counterholding bar and that'll allow you to loosen the stub center bolt.
Dupli-Color or Plasti-Kote "School Bus Yellow" seems to be a good match for people.
yundar 10-02-2013 12:31 PM
Thanks!
Thanks for the response!
