Droning Noise - 911 SC
Hi Guys,
Car is 79 SC with new wheels/tires. When I steer a BIT to the left (hardly at all) I get a loud droning noise from the rear end. This is whether the car is in gear under power or in neutral and coasting. If I turn the wheel a bit the right of center (or just about center), the droning noise goes away. I'm really stumped, any ideas??? |
Wheel bearing :)
Or CV joint. Does it increase in each gear or is it constant?
Yup. The classic sign of a bad or loose wheel bearing. A total pain, but not the end of the world.
The droning sound changes as the speed changes, the frequency gets lower at slower speeds.
Is there a way to determine which side? i.e. if turning left (A bit) causes the sound then does that indicate a particular side? Thanks for the help so far! |
Chew on that idea :) |
Wiggle test?
| All times are GMT -8. The time now is 04:17 AM. |
