Late 80's 22mm front sway bar question
Does anyone know if the 22mm late 80's "under the car" front sway bar and its 4 correct bushings fit correctly and directly into the pre-existing welded mounts on the control arm and the center mounts to an 1981 911 SC?
Thanks for any info |
I'm pretty sure they do. I just picked one up for my '76 and with the 22mm bushings it should fit.
Works great! Installed one on my '80SC, no problem.
Absolutely. Perfect fit.
BUT- I wouldn't do it without the corresponding larger rear sway bar too. 81 SC uses 20/18 front/rear sway bars The Carrera bars are 22/21 If you change just the front bar you'll end up with a 22/18 combo. |
Awesome, thanks guys!
How about earlier in the 74-77 cars??
I've got the stock front and rear bars from my 1986 930 I'd let go cheap. I know the 86 and up bars are larger the other years but am not home to say exactly what they are. Look it up and PM away if interested.
| All times are GMT -8. The time now is 03:53 AM. |
