Another CIS car causing trouble
I have been searching through all of the CIS threads looking for a answer for the past 4 months and am still stumped. My dad is perfectly content do just drive the car, the engineer/mechanic in me wants to know exactly how everything works so i know whats going wrong.
My dad and i have a 77 911s, fresh out of restoration 4 months ago. The restoration was a 15 year process because the shop is owned by a friend of ours and my dad made the mistake of saying "take your time." So long story short, after 15 years he/we finally have the car back. Its been taken apart, media blasted, repainted, engine completely rebuilt. Dad's the original owner, engine and transmission are the ones that came on the car out of the factory. Everything has been mostly smooth sailing, though in the past 4 months the car has been towed back to our shop several times. Since getting the car back 4 months ago it has been hard to start cold and after any period of time sitting longer than about 30 minutes. To get it started the engine has to crank and crank seeming like its having to draw fuel back into the lines. Once it catches it sounds like only one or two cylinders are getting fuel for a few seconds as the rest of the engine catches up. Once running its smooth and perfect. Immediately after getting the car back there was a lack of power up to about 3000 rpms, and we discovered that a backfire had cracked the airbox. Airbox replaced and pop off valve installed, fuel system pressure checked to investigate the hard starting. WUR replaced since the control pressure was sitting at 10 bar instead of 3. Mechanic says all other pressures hold as they should hot and cold. To humor me, fuel filter replaced as well. Hard start issues persist... Couple weeks later I'm driving to the local dealer to get extra keys (i know to order though this site now, dealer is pretty useless), right now we only have 2 and one of them is worn completely smooth (but still works in the ignition). So i want to make sure we have a copy made of the good key before it wears down. Pull into the parking lot and i smell raw gas, not just rich exhaust smell. Look under the car and it is pouring gas, high pressure fuel line ruptured just after the banjo fitting on the pump and was spraying everywhere, including on the brake disk. Fuel line replaced and the hard starting still persists. At this point I'm totally out of ideas, I've read through all the CIS primers i can get my hands on, bought the books on the 911, and as a stop gap measure got a battery charger/tender to deal with the couple minutes of cranking to start before every outing. But i want to be able to get the car back to being able to crank and go. The only thing I'm thinking of doing is adding a in line check valve to the fuel pump, but since the whole fuel system pressure checks fine it isnt really necessary, right? https://sphotos-a.xx.fbcdn.net/hphot...78530427_n.jpg yes the tail isnt original to the car, it was the one non original impulse my dad wanted on the car |
First, a beautiful car. Congratulations to you and your father! Original owner too!
My first reaction to your post is to ask the mechanic to give you actual numbers on your pressure tests, and especially specific numbers and times on the residual pressure test. Your symptoms are typical loss of residual pressure types. Loss of residual pressure may be from a faulty fuel pump check valve, fuel distributor relief valve, or fuel accumulator, but rather than replace parts unnecessarily, you need to get the actual values on the residual pressure test. We cannot really help you without the data and a mechanics words that things are "normal" mean absolutely nothing. I would suggest you have him perform another complete set of tests--system pressure, cold control pressure (including the ambient temp), warm control pressure, and residual pressure--since you had a new WUR installed. Ask him to record the data for all tests, including how long the system held pressure after shut down. Let us know what you find. Edit: Adding a check valve to the fuel pump is a solution for residual pressure loss and we don't know for sure if that's happening, though it's highly suspected. Here's something you can do in the meantime. Next time you have a difficult start, don't try to crank it to life. Instead, remove the air filter, turn on the ignition, and gently lift the plunger inside the air intake. Hold it up for ~2-3 seconds or until you hear/feel the vibration of the injectors. Now, try and start the car. If it immediately fires up, you have a residual pressure loss issue. |
"Since getting the car back 4 months ago it has been hard to start cold and after any period of time sitting longer than about 30 minutes. To get it started the engine has to crank and crank seeming like its having to draw fuel back into the lines. Once it catches it sounds like only one or two cylinders are getting fuel for a few seconds as the rest of the engine catches up. Once running its smooth and perfect."
30 minutes after being at full temp? Cold start after sitting overnight? Who replaced the airbox, and was the CO% set to factory spec? Makes me think that a mistake might have been made hooking up the cold start injector, or possibly the sensor plate plate was damaged/bent during the big bang - or it wasn't checked and set/adjusted when the airbox was replaced. Both items are critical for proper cold starts. That said, a check valve at the fuel pump is always a good idea, and a new fuel accumulator won't hurt. And there is a temp switch in the left side chain box cover; it should have a rubber boot over two wire connections. Those wires will be fragile, and are pretty easy to break during install if it's not done with kid gloves. Don't worry if the boot is gone, they will rot away and are often discarded. But the wires should handle a gentle tug. Post if the wires are clean & tight; the switches are bullet-proof so I'll have to get out the manual to check the test procedure - it's been a long time. |
To test this pull the injectors and measure flow/time for each cylinder simultaneously. |
Thanks for the quick feedback.
Im back at school and about 5 hours away from the car, but i will have my dad take it back to our friend for pressure tests and get a report on the results Airbox was replaced by our mechanic, they had the entire injection and intake systems apart for the diagnostics, so something being left off during reassembly is entirely possible. CO% was set back to the factory spec after WUR replacement. the 30 minutes is pretty consistent regardless of how warmed up the engine was, I have yet to see how the car handles cooler weather since it has been during a summer of 80-100 degree days. I never would have even thought to check the fuel head diaphragm, i will past that on to the mechanic as well Im absolutely in love with this car, i have memories of riding around in the clamshell seats as a kid, and now getting to drive it puts the biggest smile on my face. |
Sounds like fuel pump check valve. that would be the first fix i would do and it's the cheapest.
that year pump location is on an angle and if the valve goes it's easy for fuel to flow back to tank. Next would check ACC |
The fuel line bursting may indicate a problem further upstream which may also be the car of hard starting. look for a common link
This is interesting. "WUR replaced since the control pressure was sitting at 10 bar instead of 3."
Since system pressure is around 5 bar, how could this be? I don't think it is possible. I would recommend leaving the fuel distributor alone. The only part I would say to check is the pressure regulating valve, which can be accessed by removing the cap nut. Splitting the fuel distributor halves can cause trouble when resealing. Make sure it is a problem before opening it up. An injector test can be done by removing the injectors from the intake runners and placing in individual containers to verify equal spray patterns and volume. There are a couple of threads on this test. I would verify system, cold and warm control pressures again. Also make sure the Thermo time switch is working. |
Unrealistic number!!!!
Tony |
Just an observation - If the system pressure checks at the proper number - 5 bar or so - the control pressure can't be at 10 bar - physical impossibility. The control pressure maxes out at the system pressure. Maybe a decimal point was left out. 1.0 instead of 10?
Actually the pressure can spike from 75 to 150psi, which will blow the lines and destroy the fuel distributor diaphragm.
How? Return line occlusion. This may or may not have occured, but it is possible. . |
I just assumed the original poster (who wrote "the whole fuel system pressure checks fine") was referring to normal steady-state measurement conditions. I am having a hard time understanding how 10 bar control pressure can co-exist with a 5 bar system pressure, since both are set in the lower chambers of the fuel distributor. Caveat to the above... Just when you think you have everything figured out, something new rears it's head. We are (or should be) always learning! |
My -.1eInf cents worth.
i'm only posting to see if i have it will high fuel pressure cause no start? would this flood out cylinders? all this is fresh with me also. below is what i am doing now for my CIS It was expalined to me it should try and fire to matter what in start. if no start.. bump the sensor plate with igntition on listen for squeal of injectors. if so, fuel is there (pressure still questionable) then on to cold start injector and circuit. since i tested this sensor plate fuel delivery once. My intermmitant no start has not repeated itself. note: wealth of misinfo |
I was quoting what our mechanic told me, hes originally from germany, english is his second language so maybe he meant system pressure not control?
Ive been hesitant to turn a wrench on the car myself, just because i would beat myself up if i ever broke anything. But at this point i want to get my hands on it and make sure I'm doing exactly whats supposed to be done. Plus its more fun to learn the car by doing the work rather than dropping it off and saying make it right. That being said, im going to start by getting a fuel pressure testing kit, and running all of the system checks myself to figure out exactly what the car is doing. Im a engineering grad student at the moment though so time is precious and the car is sitting 5 hours away from me. I might not be able to get to it till thanksgiving. I appreciate all the feedback and will test out all of the theories once i can get my hands dirty again and report back. |
When you do your pressure tests, make sure you record which WUR you have and the temperature @ which the test was done.
Here is a set of charts for various midyear WURshttp://forums.pelicanparts.com/uploa...1378845791.jpg As you can see, if you have the 033 WUR, a cold test @ 15C (59F) should yield a CCP of .8bar (12psi). The control pressure will rise as the engine warms up. After about 3 1/2 minutes or so it should top out @ about 2.3 bar (33psi). Your fuel system pressure should be constant @ about 5 bar (72psi). |
I should add that you should hook up your gauge in the evening, bleed it down, and take your measurements the next morning. Have a good thermometer near your car!
Paul's charts (Canada numbers?), for the 033, are a bit different than the Porsche manual's numbers. For instance, 20C (68F) dictates a low of 1.8 bar, and a high of 2.2 bar (w/test vacuum of 520-546 mbar) as the acceptable range, compared to 1.2 to 1.7 (approx) bar on Paul's chart. This would indicate that USA cars are set to start with a leaner mixture. That said, system pressure has a small range from 4.5 bar (65psi) to 5.2 bar (75psi) as acceptable. |
Peter,
Those charts are from the blue Porsche CIS troubleshooting manual that came w/ the car as delivered to Atlanta in the fall of '76 so they are for US cars. Even though I live in Canada now and have a different engine, the car was originally sold to someone in Atlanta and had the 2.7L. Which manual are you quoting from? Is it a Bosch publication? I find it disturbing that the specs should vary so much... http://forums.pelicanparts.com/uploa...1378864196.jpg |
911 CIS Primer - Testing: Pressures See the notes on this page under "Warm-up Regulator Specifications". The Troubleshooting Guide was generated for both US and ROW cars, while the Shop Manuals available to us here in the US were for US only, not Euro cars, except where some models overlapped. |
Ive been home a few days and got some time to tweak, all pressures and residuals are spot on.
Its been cold here the past few days though, 25-35F and the car is feeling like its running lean till it warms up completely, unfortunately with as cold as its been the oil temp doesnt seem to be rising much above 120 and nowhere near the 170 mark on the gauge. Its hesitating, sputtering and backfiring at low rpms, ive given it a 1/4 turn clockwise to richen the mixture, but its trying to snow right now so i havent taken the car out to check but noticed something in the process.. In the airbox under the distributor it is occasionally squirting fuel into the airbox directly beneath the distributor and metering device. Cold starts are still a problem, but when i "prime" the fuel system first by pushing the plate briefly, the car catches on the first try, runs for a few seconds then dies when it runs out of fuel. I assume this indicates some sort of issue with the cold start valve? since it seems the car has air and good spark, just no fuel till youve been cranking for a while. If you give it fuel it catches and runs perfectly till the fuel runs out. Is there some component that controls fuel injection while cold starting for the first 10 or so seconds that im not aware of that would be gumming up the works. Im eager to get this car running perfectly because it seems to be so close, and once it does we can start taking it on trips further than 100 miles from home since thats the limit of what AAA will tow for free. |
There is a cold start injector, but it is not in a position where it would squirt fuel directly where you have indicated.
Sounds like you may have a worn out fuel distributor. Fuel may be leaking past the control piston into the air-cleaner side of the air box. |
At NO time should you see fuel in the visible, open to view, part of the air box. The cold start valve is opened by the starter voltage unless the engine is warm (above 45˚C, IIRC), or it is being cranked much longer than normally required. "If you give it fuel it catches and runs perfectly till the fuel runs out." What is meant by giving it fuel, and till the fuel runs out? How do you "give it fuel"? and until the fuel runs out of what? Please give us a little more info - |
Does your car have a Themo-Valve? It should.
Car has a thermo-valve, one of the wires, not the yellow one, was connected with a butt connector which i snipped out and soldered in a piece of wire instead, no change on starting behavior.
by giving it fuel i mean forcing the injectors to activate by pushing on the plate for the distributor for a second But with fuel leaking into the intake box theres a bigger issue with the distributor |
I will go back off the mixture before driving as well
That's the last thing you want to tinker........
Tinkering the mixture setting before verifying the absence of air/vac leak is the most common blatant mistake many people commit in CIS troubleshooting process. You could be right that you 'feel' it LEAN and there are two side of the coins: lean condition because of excess air (metered & unmetered) or lean because of insufficient fuel supply. You don't know the condition at this point. Do this adjustment later on and attend to the more critical ones. Before you even attempt to troubleshoot the cold start problem fix the fuel leak coming from some where the FD. There should be no sign of fuel leakage any where around the FD or in the whole car. Pressure test the system by running the FP and check for fuel leakage. Avoid lifting the AFS arm to prime the fuel lines because you are also dumping raw fuel in the combustion chambers. If your FD is defective or not, has to be tested and confirmed. In your eagerness to start the engine and test drive it, you might end up with a file of ashes in your garage or worse, burn your house down!!!!! Sit back and relax. Your problem is minor and you are just overwhelmed at this stage. I've not seen or known a CIS problem that these guys could not diagnose correctly. All you have to do is have an open mind and listen to suggestions. Feedback on a timely manner and reply to questions brought up. If you don't have the time to attend to the troubleshooting work, simply let us know. Don't ignore and you'll be rewarded. Tony |
Thanks Tony.
We had the vacuum leaks previously tracked down prior to the installation of the pop off valve. The whole intake system was tested and rebuilt with new gaskets etc and the engine re tuned and leak checked. My concern is that this was done in the peak of summer, 90% humidity 95F days, and the car is having trouble coping with the cold weather. I agree the fuel leak in the FD needs to be addressed, today was the first time that ive watched the car start with the air box open to even see it. Normally i dont and i dont intend to continue priming the fuel system, it was just an attempt to get more understanding of the situation. At this point our plan is to deal with rebuilding or replacing the FD and going back to the mechanic for tuning with gas analysis, then we can return to focusing on the cold start problem |
Blue Book & Good Gauges
It is likely that the Themo-valve being 30 years old is not working properly. But it sounds as if you have other issues as well. You can do a simple test of the thermo-valve by testing it to see if it opens and closes based upon ambient temperature. Many people simply bypass the thermovalve and turn mix up or adjust timing to compensate.
Definitely going to be calling Larry, just saw the price of new FDs
Im hoping its the thermo switch as well, i left my voltmeter in my apartment when i brought everything else up to work on the car. |
My car had the same hard start cold and after sitting issue. I replaced the fuel accumulator and fuel filter.... All was well after that!
Only thing I will throw in is, if you have some form of leak in the FD and you pressurize the system AND the car starts, the cold start system is probably working. The car will NOT start easy if the cold start system is NOT working and you re-fresh the residual pressure when cold. If you refresh the residual pressure when warm and it starts (where before it would not) then you have a residual pressure issue. You said residual pressure was spot on. That means it holds 20+ psi for many several tens of minutes. |
The car has no issues with warm starts, its that first start of the day that takes 5 or 6 long cranking attempts before it catches, when it catches its rough for a bit and then smooths out to perfect.
Im putting all further testing and tinkering on hold until the FD is resolved, with a leak going on, any current tuning and tweaking will need to be redone when the FD gets rebuilt or replaced. |
| All times are GMT -8. The time now is 12:41 PM. |
