-   -   Found my clutch problem (http://forums.pelicanparts.com/porsche-911-technical-forum/770483-found-my-clutch-problem.html)
2stroke 09-09-2013 09:10 AM
Was driving great one day , and the next it was hard to get into gear and then wouldn't work...http://forums.pelicanparts.com/uploa...1378743003.jpg
2stroke 09-09-2013 09:18 AM
:)http://forums.pelicanparts.com/uploa...1378743493.jpg
Where do I get a new clutch fork?
GH85Carrera 09-09-2013 09:20 AM
So how much "while I am in there" did you do? ;)
2stroke 09-09-2013 09:32 AM
I'm still there! I ordered throttle linkage bushings with the fork. Have sume oil leaks, but can't really get to them where it sits.
Joe Bob 09-09-2013 09:32 AM
Been doing any hard launches?
tobluforu 09-09-2013 09:52 AM
What the hell is that in the right side garage spot?
2stroke 09-09-2013 11:00 AM
No hard launches...only owned it about a month.....it's a Toyota!
2stroke 09-09-2013 11:12 AM
Is there a write-up anywhere on replacing the clutch fork?
911Freak 09-09-2013 11:21 AM
There is a small dowel to punch out in the clutch fork as it mounts on the shaft. You drive it out towards the bell housing and pull it out with pliers.
Make sure to order the shaft seals x 4, and make sure to clean and lube the clutch shaft as you put it all together. I use copper anti seize or white lithum.
Drop the C clip from bottom of shift fork shaft where the omega spring assembly is and if your lucky the whole assembly drops off after you remove that fork dowel.
Many many threads on this.
UTSF and you will find them or check the 911 tech articles.
1 hour job tops if you have everything.
I ordered my shift fork and shaft seals from..... Pelican!
Who else?!
Good luck.
pete3799 09-09-2013 11:23 AM
Drive out the roll pin (visible in your picture) slide shaft down, replace fork.
gled49 09-09-2013 11:59 AM
I polish all the casting flash off the new forks to help stop stress risers and possible future cracks. Gled
