"Spare parts" engine install...
Hi all,
My engine install on my 82 SC is slow and stready. Today I installed clutch cable, omega spring and levers. This clamp was in the box with the cable stuff, but I cant find a place for it.
Any ideas?
Christian
Old 09-10-2013, 06:32 AM
Fuel line clamp? (In the wrong box?)
Old 09-10-2013, 06:53 AM
fastfredracing's Avatar
Clamp for the vacum line that runs to the power brake booster. should be on the drivers side of the motor about halfway back.
No left turn un stoned
Old 09-10-2013, 07:10 AM
muck-raker
kidrock's Avatar
Misleading title. I thought this would be another Motor Meister thread.
I wish I could find about 6 of those clamps.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-10-2013, 07:15 AM
schumicat's Avatar
that's a typical fuel injection type hose clamp found at any auto parts store.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-10-2013, 07:19 AM
Thanks a lot all,
Probably vacuum line clamp in the wrong box but the brake booster is in the trunk!?
The fuel lines are all connectiions with nuts as far as I recall. (connected them yesterday)
edit. Probably the vacuum line for the charcoal cannister - that one is missing. Thanks for the input.
Old 09-10-2013, 07:31 AM
