Josh
Removing Wiring Harness
Trying to remove the wiring harness from my 75. I read a few other threads but not entirely clear.
1. Am I correct that the harness comes out best by pulling it out through the rear of the car? 2. Can this be done without cutting the harness? Almost every every comment I have seen refers to cutting the harness and I would love to avoid that. Any input is appreciated. |
Yes Josh ,you'll pulling out the harness from the back.(because the T14 plug)
I did it on my 74 chassis and I didn't cut the wiring harness. If I remember well you'll have to separate the part which is going to fuses from the part going to gauges. It was 9 years ago so difficult to have a clear memory but definitively I didn't cut the harness. JM ![]() Last edited by jm58; 09-12-2013 at 09:22 AM.. Reason: no image |
