Thread Killer
Teutonics's Avatar
3rd brake light?
Can anyone recommend possible 3rd brake lights (where to buy, from other cars/models, etc.) to add to an '85 911?
I just bought the car, and already had someone almost rear-end me. (911 brakes are awesome!)
TIA!
Allen
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 08-24-2002, 12:02 PM
I depends on if and what style tail you own, or if you want it inside.
If you like stock Carrera brakes, you'll love the Turbo version.
Old 08-24-2002, 12:07 PM
Thread Killer
Teutonics's Avatar
Yes, it has a tail, but I would prefer inside high mount (don't want to drill anything!)
Thanks!
Allen
'85 911 Coupe
'75 BMW 2002
Old 08-24-2002, 12:12 PM
Don Haney's Avatar
Im 5'11 and could not see behind myself with the stock C2 High mounted 3rd brake light. I had to lean if I wanted to see what was fast approaching. I would think the targa mounting down low would be better if you can still see the light over the tail?
I ripped out the assembly the 2nd week of ownership ! The C2 has a different center reflector than yours and I was able to access the rear Fog Light provision and use them as 3rd brake lights. They are bright and you cant miss me..
I know its not stock, but a good alternative. While in there I also changed the tail light wiring around little. Now my turn signals light up amber with the red tail lights and flashes as blinkers when needed.
I personally like the look, and since the wiring harness is part of the lens assembly on the C2, it wasn't like it couldn't be undone.
I have since been informed that the lighted Ambers can get you pulled over? I hope not, since I like the ambers lights. Never had a problem in my 74 911 or the 914-6 set up the same.
I'll sell you my fact 3rd brake light. It was on the ebay item list, but yours if you want it.
Don
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 08-24-2002, 04:05 PM
I've been trying to figure out a way to light up the entire rear reflector as an additional brake light, sort of along the lines as Don. Has anyone does this? I know the idea has been floating around but i've never got around to it.
Old 08-24-2002, 05:45 PM
Paul, there just is'nt enough room behind the center reflector to get any lights. I even looked into LEDs and they require more room than is available. You could drill big holes {2"} in the panel behind the reflector and mount sockets and bulbs but they would only shine through in small spots, not an overall glowing effect. Unless you want to add 7 lights
[one behind each letter} you won't get the effect your after.
Jerry
Old 08-24-2002, 06:28 PM
Thread Killer
Teutonics's Avatar
Thanks Don! I sent you an email.
Allen
Allen
'85 911 Coupe
'75 BMW 2002
Old 08-24-2002, 06:50 PM
