-   -   Problem Solved - guess what it was... (http://forums.pelicanparts.com/porsche-911-technical-forum/77125-problem-solved-guess-what.html)
RazorRacer 08-10-2002 04:41 PM
O.K. this problem that I have been chasing for the last 6 months or so is solved. If you are interested, let's play a game. You guess what it was and I tell you if you are warm or cold. The first person to guess the complete answer gets a $50 gift certificate to Pelican Parts.
Here are the clues:
Starts great hot or cold.
Runs good until warm then there is hesitation at constant speed.
Runs great above 5800 rpm if hot or cold.
Big clue: previous owner only half way fixed the problem.
Here are the things I tried to fix it, but they didn't work:
Replaced fuel filter.
Replaced fuel pump with internal check valve.
Sprayed carb. cleaner to check for vacuum leaks - NO LEAKS.
Set timing.
Checked electrical distributor cap - fine.
Checked fuel distributor for a fouled plunger, but failed in my efforts, but that wasn't the problem.
I could give the answer here, but if you are interested, let's have some fun.
Bottom line: problem solved and I am :)
pwd72s 08-10-2002 04:48 PM
The answer is too easy! You gave it away in your signature..
It's a Targa. They ALL do that. Apologies...I really don't have a clue. But how many times have we all heard those four words from a dealership service manager? (An oxymoron in it's own right.."service manager") THEY ALL DO THAT???? Like by saying this, "THAT" is suddenly okay? :)
avi8torny 08-10-2002 04:48 PM
fix
temp sensor or flywheel position sensor...that's my guess.
Adam 08-10-2002 05:02 PM
Ok..
It's gotta be related to the injectors, right? Needless to say, they'd get new seals if you replaced them. Possibly the Beru connectors/plug extensions also. They were a major fault on my 2.7, causing it to run on 4 glorious cylinders!
RazorRacer 08-10-2002 05:25 PM
Adam: injector - cold
avi8: flywheel positioner - cold. Temp sensor - cold.
72s: WTF?
I'll be checking reply's tonight and tomorrow morning, but I have a race all day tomorrow. Then back at it again Sunday night and the rest of the week.
Is this fun?
adamnitti 08-10-2002 05:43 PM
razorracer, i don't have a clue, but i'm just glad it's fixed! congrats!
RazorRacer 08-10-2002 05:44 PM
Thank you Adam. This is a high moment in my P-car life.
Bill Douglas 08-10-2002 05:49 PM
Razor, I'm pleased it fixed. This has been bugging me too being an SC man.
Was it due to the charcole filter being removed and a leak getting into the airbox causing a lean mixture?
Bill '79SC
RazorRacer 08-10-2002 05:56 PM
Thanks surfer dog. My board has been neglected in my P-car efforts. Not much wave here in Houston.
Sorry to say that the charcol filter is cold.
Man, I'd love to try some down under waves.
Kevin Stewart 08-10-2002 06:11 PM
Lets see how about the cdi connection or box, Kevin
joeycatt 08-10-2002 06:14 PM
Razor!
Time for mucho joy! I'm waiting to hear what it was....(obviously none of the things we suggested)
The excitement builds....:D
A Quiet Boom 08-10-2002 06:19 PM
The vacuum advance unit on the distributer was bad.
Specifically the spring in the vacuum advance was allowing too much timing to early in the rpm range, once the engine reaches 5800 it's close to the point where total timing should be in effect and therefore the problem "goes away" since the engine needs that much advance at those rpms.
Possibility number 2 would be a no-functioning mechanical advance which wouldn't give the engine enough advance under load when the vacuum signal is weak and therefore the vacuum advance is barely functioning.
Overpaid Slacker 08-10-2002 06:21 PM
Razor --
The muffler bearings?
There's nothing like putting a stake through the heart of a tenacious automotive problem -- congrats!
- JP
Bobboloo 08-10-2002 06:23 PM
WUR?
Bobby
RazorRacer 08-10-2002 06:45 PM
joeycat: thanks for all of your help. You kept me going throught the rough times.
boom: you are very warm with #1 and I think you have answered the problem. It's not exactly what I was expecting for an answer, but you have the right idea. Can you please elaborate for us who are not a knowing as you?
Slacker: WTF? muffler bearings?
bob: WUR was a first check. Took the vacuum line off and expected the problem to go away, but it didn't. WUR: cold.
Kevin Stewart 08-10-2002 06:48 PM
Ha you mean tha cat converter was pluged, Kevin
RazorRacer 08-10-2002 06:53 PM
Kevin: cat converter was not plugged. Should have mentioned that as one of the things checked, but forgot about it.
Boom: you have the answer, but please elaborate on how you knew this. Many before you have tried, but you hit the nail on the head. I want to share my personal experience how I found it, but am waiting to hear more from you.
Overpaid Slacker 08-10-2002 06:57 PM
Razor -
A joke. I had no clue.
PO halfway fixed it?
JP
Kevin Stewart 08-10-2002 07:03 PM
i believe boom has the answer also, as either the advance was rusted or the wire to the distributor was bad, if it is the answers it was booms, yo da man boom, :D , Kevin,,,, i think i am spending to much time on this bbs, i need to get a life and stop eating sleeping, thinking Porsches all day, well maybe not when I sleep,:rolleyes:
rstoll 08-10-2002 07:04 PM
Fuel pump relay socket.
RazorRacer 08-10-2002 07:10 PM
The answer : the PO had put a tip of a pencil in the vacuum line to the vacuum advance of the distributor. It held off vacuum for a while, but not completely. After running for a while, the vacuum did engage the advance and the engine started hesitating.
I replaced this with a new vacuum hose and the problem got worse. I then tied the new vacuum hose in a knot and the problem completely went away. I guess the knot was better than the pencil tip!
I will arrange a $50 gift certificate for boom next week. But I would still like to know more about the vacuum retard and how it's supposed to work.
Congratulations boom - you the man!
Kevin Stewart 08-10-2002 07:13 PM
Razor racer thanks for keeping us intertained it was fun, enjoyed it, Kevin
RazorRacer 08-10-2002 07:16 PM
Kevin: just sharing my joy!
Kevin Stewart 08-10-2002 07:24 PM
the reason i was so intereted was i spent almost a year chasin a gremlin, the car would stall, for no reason, one day i got piizzed and was gonna find and did, it was a dirty plug to the cdi box, know the car is a joy to drive again, i have had the car five years and promised myself if it wasnt fixed by fall I was gonna let the kids hit with a sludge hammer for 10 bucks a pop, but as it goes i have converted it to a wide body c2 look and did a cab conversion, maybe a 3.6 with a g50 this winter, and heres wishing you many more happy days with her, i mean car, post a picture, would be nice to see what car we were all guessing at, Kevin
RazorRacer 08-10-2002 07:53 PM
1 Attachment(s)
G'night all.
Kevin Stewart 08-10-2002 08:18 PM
Great looking car, Kevin
A Quiet Boom 08-10-2002 09:08 PM
Cool, I thought I might be right but I couldn't find a reference to what the PO had done anywhere in your other posts. How did I know? Well I've been installing a 3.0SC into my '66 912, I had both the vacuum lines disconnected because I'm running carbs and the motor broke up just like you mentioned. My initial timing with the lines disconnected was way to advanced. I also noticed with my timing light that the mechanical advance is very fast bringing it's maximum advance in at less than 3000 rpms. This lead me to look at the vacuum advance/retard unit. Basically both units attach to the throttle body with one above the throttle blade and one below (can't remember which is which) this means that the one below the throttle has a vacuum signal at all times except WOT (wide open throttle) the line above the throttle only has vacuum when the throttle blade opens and I believe it's proportional to throttle position. Anyway my engine also "free revved" fine like yours and since we are running different types of induction but exhibiting the same problem I had to look at what the engines have in common. I'm running an MSD box in place of the stock CDI as well so I ruled out the CDI, ruled out induction and fuel problems which left only one possiblity the distributers advance mechanism. I figured either yours had a weak spring on one side or the other or their was a hole in the diaphram. To further investigate as well as complete my ignition system I removed my vacuum advance and welded the plates together as well as welded the mechanical advance together, in effect giving me a locked distributer with no advance curve at all in anticipation of my next step which involved installing an MSD timing computer. I set the motor for total timing at 32 degrees BTDC and took it for a test drive, my problem was even more aggravated leading me to believe that 3.0 motors are very touchy when it comes to ignition advance. I then installed my timing computer and set the initial timing to 10 degrees BTDC with the curve starting at 2000 and total timing in by 5500. The problem is all but gone! A little more tinkering and I think I'll have it but I also need to adjust my accelerator pump circuit to more closely match my engine. My main clue though was when you stated that moving your initial timing to 5 degrees ATDC the problem was almost gone.
Well I'm certainly happy that you've fixed your car and that mine is almost done. I also don't feel that I deserve a gift certificate for fixing your problem after the fact, I only wanted to share a little knowledge with you and others, but then again this board is supported by Pelican Parts so if you/I spend $50 it only helps insure that we maintain this great resource. Best of luck! :)
A Quiet Boom 08-10-2002 09:25 PM
BTW, try one more test on your engine. Reattach the vacuum retard line, make sure it's attached to the throttle body in the correct position and set your initial timing at 5 BTDC. Test drive the car and see if the problem has returned before you eliminate the retard function by disconnecting it or before you replace the unit. I'm guessing it's probably bad (since the PO blocked the line) but this would be a way to know for sure.
Bill Douglas 08-10-2002 09:43 PM
Good man Boom!!!
Razor, now that the 911 is going ok you may end up saving some money for an air ticket down under. Why not fly down in January or February and we could do some very nice surfs aound the Wellington district, then round it off with a few high speed runs up to the wine making areas to the north in the SC. Then combine it with a trip to fabulous Australia where Fishcop, Adam, Merv and the rest of the team will entertain you.
Bill SCWDP - south pacific region
wckrause 08-11-2002 06:43 AM
Wait a minute. How can you say your problem is fixed when you've disconnected your vacuum advance? Vacuuma advance is for better performance at low RPM's with an open throttle, it's not an emissions issue.
You've still got some work to do.
Superman 08-11-2002 07:04 AM
True. when you first open the throttle to take off, there is some retard going on, and even at lower cruising speeds because the vacuum advance wants to advance the timing too much. It helps prevent the kind of detonation that happens when you suddenly open the throttle at low engine speeds.
but of course, if you've put carbs on or something, then those (timing) curves will be affected.
wckrause 08-11-2002 11:03 AM
78SC's only have vacuum advance. Vacuum retard was put on in 1980 along with K-lambda. (I think)
RazorRacer 08-11-2002 04:01 PM
Yeah, I still want to fix the vacuum advance. But at least now I know what the problem is and I can drive at constant speed, now, too.
Hey, I'm even going to participate in the next track day at Texas Motor Speedway in September!
RazorRacer 08-12-2002 04:47 AM
Surfer dog, I have checked air fares and a roundtrip to New Zealand is around $3-4K. Are there any better rates then this?
CamB 08-12-2002 05:17 PM
Wellington to Houston return should be around US$1500 per person.
You should be able to find a cheap fare from Houston to LA (or any other hub with frequent flights to NZ - I have only ever flown to or through LA on Air NZ). The figure I have in my mind is usually ~NZ$2500 (~US$1150). However, it seems to be much cheaper to fly NZ-US-NZ than US-NZ-US. They are screwing you ;)
Auckland to Wellington is less than NZ$300 (under US$150). Maybe even NZ$200.
MotoSook 08-13-2002 06:16 AM
Wahooo! Go Razor Go!
Not to take anything from Boom, but Joeycatt started the revolution on the advance. Good for all and Boom for the investigation. Without the testing, it's all speculation.
You guys are grreat!!
