-   -   Strange noise after switching to SSI exhaust (http://forums.pelicanparts.com/porsche-911-technical-forum/771500-strange-noise-after-switching-ssi-exhaust.html)
aldente295 11-28-2013 10:30 AM
Originally Posted by willcall (Post 7779632)
I'm certainly no expert but if you are having power loss it could be the O2 sensor. If they read incorrect levels of mixture they can retard the power and no amount of reving will bring the engine to life, so to speak. May mean the O2 sensor needs to be moved further into the exhaust flow or further away by using a spacer bolt.
This is interesting! The SSIs didn't have an O2 bung, so I had to have one fitted. I wonder if that could be the issue?
JJ 911SC 11-28-2013 11:41 AM
Maybe the cutout fell inside the SSI...
aldente295 11-28-2013 03:49 PM
JJ - Wish it was that simple, but definitely experiencing power loss too.
JJ 911SC 11-29-2013 01:08 AM
I Should have watch the video…
Following Willcall theory, post a pic of the SSI with the O2 bung to compare with a factory one.
turborat 11-29-2013 12:53 PM
Be very careful running high RPM until problem fixed. Thinking AFM is too lean because of more free flow exhaust. Noise may be pinging that will eventually break rings and pistons. Richen fuel mixture and test. Your '80 does not have O2 sensors. Suggest AFM meter to test. Dyno shop will have one.
Jay Laifman 12-01-2013 04:22 PM
I can't tell from the video. But, is there a chance that one of the gaskets for the muffler is bad? I have a car that really likes to blow exhaust gaskets (yes, I know the flange is not flat). But, when it happens it makes a bad noise. To me it sounds more like a tapping valve, but also causes vibrations in the sheet metal adjacent to the port. I don't necessarily think that is what is happening here. But it is a noise and it came after the exhaust was changed.
aldente295 12-01-2013 10:05 PM
Jay - In your experience, when it blows an exhaust gasket is it possible to 'only' hear the noise under load? If I sit in the garage and rev the engine by hand, I don't hear any bad noises, even all the way up to redline. But if I drive up a hill and rev over 5K, I will hear it every time.
turborat - Hope you don't mind, I've just copied your PM into here for the benefit of the group:
Can't think of a connection of power loss and exhaust replacement beyond the AFM. The CIS is a passive injection system. A more modern OBD I or OBD II system would make adjustments from O2 sensor input. The CIS acts more like a carburetor where one would have to rejet, the CIS will need adjustment......unless something was disturbed during the install. Check all vacuum routing, fuel pump and fuel filter. Also look at ignition. Cap, rotor, wires and box. Is ignition OE OR change to something else? Might also pull the injectors one by one and spray them onto a clear glass jar. Looking for a wide spray pattern. They are fairly cheap to replace and cannot really be cleaned. An AFM under load at higher RPM will tell for sure. Paul
There is actually a 'basic' O2/lambda system on the '80 model. However my understanding is that at WOT it doesn't do anything - it only works on improving fuel economy below (I think) 35% throttle or so.
JJ- Which is why I'm leaning towards ruling out the placement of the O2 sensor as a problem, since it (shouldn't) be a factor at WOT, which is when I hear the noise (above 5K)
turborat 12-02-2013 05:21 AM
Ok. I thought '81 was first year of Lambda. I have had four 911 SC and all were/are '78 or '79. On OBD I engines like the 3.2L, one can disconnect the O2 sensor and AFM will richen up considerably. You could try same thing.
JJ 911SC 12-02-2013 06:41 AM
The OBD started with the 3.6
ClickClickBoom 12-02-2013 06:55 AM
Detonation.
Change in flow via the SSIs, richen up the A/F mixture via the 3MM adjustment screw. That level of detonation, or any, over time will cause damage. I did mine seat of the pants, worked fantastic.
redridge 12-02-2013 07:11 AM
subscr! +1 on A/F mixture...
Josh D 12-02-2013 07:13 AM
If it is detonation, you may also need to pull out some timing. I'd try richeining it up first, but if that cause start and idle issues, I'd look closely at timing. It will ultimetely come down to a balance between the two (and quality/octane of gas as well).
ClickClickBoom 12-02-2013 07:30 AM
Josh has it right. After talking to Jerry W. about the subject, timing and fuel are variables that can tuned for. If I remember Jerry suggested 32 deg total advance as a starting point and adjust from there. It's all about the tuning.
aldente295 09-02-2014 04:44 AM
Originally Posted by Sway Bar (Post 7658727)
Have you ruled out the exhaust? Try your old one if it fits?
Reason I suggest it is that I recently tried from a friend a very free flowing M&K on my MFI...sounded awesome, revved great with no issues but under power at 4200rpm I thought I spun something. Worst mechanical resonance I've ever heard that sounds very similar to yours. Fortunately he had another more tame M&K that we quickly swapped out and no issues. (he's gonna have a hard time getting it back)
Anyway, was a quick check without playing with mixtures etc etc.
To close this out....
It took me over a year, but finally got around to chasing this problem down and resolving once and for all.
I eventually bit the bullet and bought a new Dansk sport muffler. I swapped it out and...problem gone! Noise gone, power loss gone, back to running perfectly.
It took me a year to get over the 'I don't want to drop another grand and still have the problem' fear...sure glad I eventually did.
The Monty id's now gathering dust in my garage til I figure out what to do with it.
Thanks to all for your many and varied ideas.
911pcars 09-02-2014 09:41 AM
Glad you found the source of the problem. No more being passed by Hondas. :)
Certainly the muffler change was less than the cost of rebuilding the engine or other random parts replacement strategy. However, you could have also substituted a factory muffler to confirm if the Monty was the source of the issue (that's called hindsight diagnosis).
It sounds like (pun) there's something happened to the internals of the Monty muffler. They may be interested in a post-purchase repair/adjustment for PR/reputation purposes. They're in your neighborhood, yes? If not, might be worth the effort to sardine-can it and see if there's a potential repair, otherwise it's of no use to the next owner or alternate use as a pricey paper weight.
Sherwood
93nav 09-02-2014 01:44 PM
Thanks for posting the resolution!!! Lots of threads where the fix/solution/cause is not given.
