Deadeye's Avatar
Rebuild late carrera axle shaft?
I ordered a new pair of half shafts and installed them but would like to rebuild one shaft to have as a spare. I can find the inner joint parts on our host's site, but nothing for the outer (stub axle) end. Is the outer end rebuildable, and if so, does anyone have any tips on working on this end?
Old 09-16-2013, 10:32 AM
I just checked the catalog, and it looks like outer and inner are the same.
Hopefully, someone smarter than I will chime in.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-16-2013, 10:38 AM
FWIW I have had mine done professionally by CV of Ocala. ~$150/shaft plus shipping.
I chose them because they polish the races, not grind them, and they'll install new balls from .001-.003" oversize to accommodate.
Got 20k mi on the rears of my C4 (rebuilt at 112k) and ~10k on the fronts, no complaints.
'90C4
Old 09-16-2013, 12:07 PM
irobertson's Avatar
On the later model shafts the cap that the boot fastens to is crimped onto the joint and is not removable, so no, they are not rebuildable. Only the inner joint can be dismantled.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 09-16-2013, 03:02 PM
burgermeister's Avatar
The outer joint can be dismantled, but you can't find a replacement for the outside race.
To dismantle, carefully grind (or better yet cut, if you have a lathe) the metal cap the boot attaches to right where it is crimped inward. You will have a ring attached to the CV, and the rest of the cap with a little lip covering the outer edge of the CV. The cap can then be removed, and the joint disassembled. To reattach, drill & tap 6 holes for M4 in the fat, soft part of the CV and bolt it back on with some short allen screws.
Update Carrera CV Boot replacement
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-16-2013, 03:36 PM
