-   -   Post Alignment Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/771657-post-alignment-questions.html)
BrianS 09-15-2013 09:33 PM
Recently installed turbo tie rods, new shocks and new tires onto my 1987 911. The tire shop did both the tires and the alignment. Now, the car steering is much easier than before and I am experiencing bump-steer that I never felt before. Has anyone experienced this after an alignment?
Chuck.H 09-16-2013 04:53 AM
Sounds like you may not have enough caster, that will certainly cause the light steering feel, at the expense of straight line stability...
Chuck.H
'89 TurboLookTarga, 363k miles
stlrj 09-16-2013 07:04 PM
Usually you get a printout after the alignment that tells the before and after specs.
Do you have it?
