D@vid's Avatar
Did the mugglers box cover ever change
Hi,
My '73 car is missing the smugglers box cover (air-conditioning) and I was wondering, can I buy just any cover, or did they change through the years?
1973 2.4 MFI
bone-stock 911T
Old 10-22-2014, 01:07 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Fits all 911/912/930 (1965-89), so yes.
1983 Porsche 911 SC Convertible - Bumpers, Doors, Latches & Lids - Page 10
Who Will Live... Will See
Old 10-22-2014, 01:20 AM
D@vid's Avatar
Great, thanks!
1973 2.4 MFI
bone-stock 911T
Old 10-22-2014, 02:58 AM
jarrodblake's Avatar
It depends on what a/c unit you have.
If it looks like this then yes any lid will fit.
If you have this one then no.
Old 10-22-2014, 04:31 AM
cycling has-been
bkreigsr's Avatar
There's an early version that is flat - (on my 73), and a newer version with a hump/bubble stamped into it, to clear the later models a/c paraphernalia.
One part number will physically fit, and bolt in, all years, but may not be correct for the model.
Bill K
Old 10-22-2014, 05:14 AM
304065's Avatar
There is an SWB version with a bump for the webasto and a tab for the heat shield
then a LWB version
Then the version with the bump for the air conditioning evaporator fan
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-22-2014, 05:53 AM
Taking it apart is easy
Jerome74911S's Avatar
I have seen different bumps on LWB versions, AC, or not. Photos of your AC?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 10-22-2014, 08:24 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I was worried you were putting muggles in the smugglers box, that would be mean!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-22-2014, 08:57 AM
D@vid's Avatar
I've removed the old non working AC. It left a hole where it used to be. I'm planning on restoring the car more or less to factoren specs an as the AC was dealer installed (and incomplete), it wil not return.
1973 2.4 MFI
bone-stock 911T
Old 10-22-2014, 09:28 AM
