911SC What is this? help
I damaged my 911, Look at the picture
What is this and Where can i buy it? This is a radiator? Any part number? Let me know ![]() Uploaded with ImageShack.us Last edited by xr650r; 09-22-2013 at 04:13 PM.. |
That is the oil cooler that is mounted to the engine. A good used oil cooler can be found in the classifieds or if brand new is needed, search the Pelican Parts catalog here.
It looks like your axle must be trashed as well. What happened?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
I hope you are OK.
What about the axle, arm, shock,...???
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Thank you
I'm ok I got hit by drunk driver ![]() I've already bought rear shock, trailing arm... |
wow.. so what does the outside look like ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Has an insurance adjuster looked at it?
Could be a lot more damage there than you think.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Grappler
I cant imagine the tub is still straight after all that internal damage.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Senior Member
You must have the frame looked over for damage - that all the measurement nodes are at their respective locations. Do not overlook this with your insurance company!
So sorry to hear of your situation. I am remotely involved in DUI prosecution and I know it could have been so, so much worse for you. Good luck!
'78 Targa in Minerva Blue |
Less brakes, more gas!
There may be a lot more damage to the engine than is apparent. The oil cooler is smashed into the valve cover/valve carrier. It may have also damaged the underlying cylinder, #6. At a min the ribs on the valve cover are probably cracked off.
I also see the front of the exhaust/heat exchanger is mushed. You will have to remove it and check the bottom of the heads to make sure you have not pulled or cracked anything there. It is obvious that the whole rear bodywork has been cut off already. Check the transmission side plates for cracks. I also suspect that the shock mounts have been tweaked given the state of the shock. Takes a fairly large force the shear that shock rod right off like that. The body shock receiver may be out of round also. At least you are well it seems! I'm assuming that insurance will total the car, no?
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Targa, Panamera Turbo
Does your neck hurt? Silly question, of course it does...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
