Rod bearings
Hi guys,
I have a crank that spun a rod bearing. Looking to get the thing cut. At this point I need to find out what oversize bearings are available so I know what to tell the machinist. On Pelican all I can find are these:
Pelican Parts - Product Information: 930-103-148-50-OEM
These say undersize? Would they be correct if I were to cut the rod journals on the crank 0.25mm?
Miles
'80SC ROW
'76S Wide Body
'87 G50 Coupe
'69T Bahama Yellow
Old 09-23-2013, 05:52 AM
jittsl's Avatar
I would assume so because that would be the only logical way to read it (it's not likely that our going to make your journals .25 larger).
You could always call Pelican to confirm.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 09-23-2013, 06:01 AM
Crank work
Miles, I would suggest a single journal repair back to STD and heat treat after the repair, We use Armando at CCR for our crank repair, he is one of the few that does this very well his # is 650 342 0568 tell him I sent you
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-23-2013, 06:26 AM
