 Checking torque on cylinder heads I've got my 2.7L engine out right now and I was wondering if it's a good idea to check the torque on the cylinder heads. Am I at risk of breaking a head stud? The engine runs great, only has 50k miles, and I'm not having any problems with it. thanks |
 You wont break a head stud, thats an aluminum case problem.  The torque will pull the magnesium threads so you will have to case save insert and install dilivar after a complete disassembly. Bruce |
 Just check to make sure they aren't loose and leave them alone... |
 Are you saying not to check the torque? It's a good question but I am not sure of the answer. |
 Great. They're not loose and I'm leaving them alone. The alternative doesn't sound nice. thanks guys :) |
 You chose.... wisely. |
 Yeah! The real fun starts when a nut and a piece of the stud falls on the ground for the aluminum case engines. Or when the nuts just keep tightening on the magnesium ones... |
 Bob, I wouldnt take them to spec, as long as they arent falling off.  Youre dealing with a sure fired rebuild on a 2.7 and that isnt cheap.... Bruce |
 Initial break-away torque is much higher than the torque spec. The most accurate torque readings are obtained as the threaded fastener rotates.  Thus, to re-torque accurately, each head stud nut should be first loosened slightly, then brought up to the specified torque as it rotates. Check for loose fasteners by applying a fraction of the specified torque (YMMV). If it's loose, you'll feel it move. Sherwood |
| All times are GMT -8. The time now is 05:57 AM. |
