turbo dreaming
Question 996 engine into older 911?
Does anyone know if the 996 engine would fit into the earlier 911s? Or would it be better to just go with a 993 engine.
Old 08-30-2001, 03:25 PM
CamB's Avatar
Post
The quick answer would be to go with the 993 engine - no need to try and fit watercooling attachments (what the heck is this ray-dee-ay-tor anyway. And you fill it with, whadiya call it, koo-lant. Come on now boy, why not just cool the engine by the very air around us. I mean its free, ain't it?).
Seriously, I have no idea if the engine mounts in easily, but know from the well-trodden path that a 993 engine bolts in fairly easily and with all the bits readily available (albeit expensive).
I would imagine the 996 headers/exhaust would require a lot of custom work too (as opposed to buying for instance the B&B setup for 964/993 conversions).
Don't even get started on trying to heat the cabin without using heat exchangers on the air cooled engine.
But if the Chevy V8 guys can do, so, with enough money, could you!
Cam
Old 08-30-2001, 04:46 PM
Stay away from my Member
campbellcj's Avatar
Post
I honestly can't think of a single reason to go the 996 water-pumper route for a conversion like this.
Old 08-30-2001, 05:36 PM
CamB's Avatar
Post
Oh, and it was discussed over on the Rennlist Board too (sorry for linking from here Wayne):
http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=1&t=000617
Try and ignore the watercooled is superior bits. Who really cares if it is true because air-cooled sounds cooler.
Cam
Cameron Baudinet
1975 911S (in bits)
1969 911T
Old 08-30-2001, 05:55 PM
turbo dreaming
Thumbs up
thanks a bunch guys, guess i'll stick with the tried n true. air cooled does sound cooler.
Old 08-30-2001, 08:44 PM
Senior Member
Post
Hello
The GT engines does "fit" as they are basically ol 935/965.
Anyhow where is the sense for a WC in the car ? American muscle is cheaper and also Watercooled.
Grüsse
Old 08-31-2001, 05:20 AM
