Seat Rail Bolt for 3.2 Carrera
I have looked in our host's catalog to no avail. Where can I purchase a new bolt for my seat rail?
Thanks so much.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Troll Hunter
Pull another one and try your local hardware store for the same length and thread.
Metric!
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
I've gotten mine from my local Ace Hardware store- Grade 10.9 too.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Cool! I was under the impression that the head of the factory bolt was smaller than standard.
ACE - Here I come. ![]() Thanks so much, guys.
Spiderman
I think it is a special bolt, the head is shorter. Not to say you can't take a standard allen head and grind it shorter yourself for an acceptable substitute. I don't think you'll find it locally.
You might look at McMaster Carr on-line. They have a huge selection. Get it in your hand and you'll see the issue.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Spiderman
McMaster-Carr Might be these, called a metric "low head".
McMaster-Carr #93070A145
Low head cap screws have a wider head to make up for the thinner head, lets you keep the torque rating equal. So, taking a normal bolt and cutting the head down is NOT an acceptable practice. Problem is the packs are 50 screws, so you'll end up with lots of extras.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I've had good luck with Fastenal. There is one within a couple of miles of where I live. The guys there don't seem to mind my buying 3 or four bolts, washers, etc at a time. I haven't had to pay shipping on orders delivered to the store for non- stocked items. They carry 8.8 and 10.9 spec hardware.
Pelican carries them. Look in the PET for the part number and plug it in the search function. The ones for my car are: 900-119-030-02-OEM
Linky: Pelican Parts - Automotive Parts and Accessories - Porsche & BMW It matters what kind of seat you have. Power or Manual, with spacers or without. So look in the PET for YOUR seat. The bolts are shoulder bolts, Not fully threaded. If you get one that's too long you can't tighten it down. Ask me how I know...
John '86 911 Coupe |
Thanks, John!!!
Metal Guru
I use a grade 10.9 button head bolt. The head is short enough to clear the upper seat track and it's not soft like the factory bolts.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
