It was mentioned to use 800 grit sand paper to prep area to be painted. My wheels are fully polished. Will I need to prep with sanding also or is that only if the area to be painted already has old paint? If so, I'm assuming the sanding is done after masking so as not to blemish the unpainted areas. Should the painted area be clear coated after paint has dried and cured? I know, too many questions but if I'm gonna do it I don't wanna f*** something up.:eek:
rbogh901 - I settled on Rustoleum Satin Black #7777 and Metallic Matte Nickel #7277.
Yes -- you'll want to sand any bare metal polished surface before painting. A light treatment with 800 grit should be fine. Paint adherence to polished metal is usually not too good. The sanding provides texture for adherence. Sand carefully after masking. You don't want to disturb the tape seal and compromise the sharpness of the masked line. You should also wipe it down with a prep solvent or lacquer thinner to remove wax, oil, fingerprints etc. Again, a light wipe down with a lint free cloth dampened with the solvent should be fine. Don't get it too wet or you will compromise the tape seal. If you look at the second to last picture in post 31 above, that surface has been sanded as described after masking. You just want a fine brushed metal finish. |
I've almost lost my paranoia:eek: about taking this project on.
Thanks Joe |
Do you think masking off the tires is ok? I don't want to remove and re-install the tires.
Masking the tires should be fine.
Another thought - since these wheels have been in use, I would clean the back sides as best you can, and mask the openings from the back. That will keep debris from the back from blowing onto your fresh paint. |
You can stick playing cards or index cards into the tight space between the bead of the tire and the rim all the way around, then tape outside of that. It leaves a much more defined space for the paint on the outer edge of the rim and really keeps all the spray off your tires, even right next to the rim surface. - Matt
Thanks. |
Thanks Mat.
I'm thinking of doing the RSR treatment on my 7 & 9 Fuchs. Would anyone be able to either show me what it would look like on a GP white car or perhaps photoshop a pic of mine.
Thanks http://forums.pelicanparts.com/uploa...1382108712.jpg |
I got some fine line tape from a local automotive paint supplier. He says to prep with a 400 grit and use a primer. It was recommened on here to use 800 grit.
I realize I've been asking a lot of questions but a couple more. 800 or 400 grit. Primer? What color, type and brand is the best to return painted area to original? I do not have existing black areas since my wheels are fully polished. Does anyone have a photo for reference to locate where the masking should be lacated? They are 6x15. not deep. http://i1296.photobucket.com/albums/...ps6c44eeed.jpg http://i1296.photobucket.com/albums/...ps7f5ecfea.jpg |
Nicely done, the wheels look good.
One word of advice, clean the paint off the lug nut mateing surface. |
Black;:confused:
Gloss? Satin? What was factory color please? |
Satin black. Wurth makes a good one, but it's tough to find and usually needs to be ordered. I've heard lots of guys happy with Rust-oleum satin black, too, but I've never tried it on Fuchs.
- Matt |
Got started this evening masking my wheels. About two hours per wheel but I took my time to make sure all the petals where masked off the same length and width. I put two quarters in two of the lug holes on the bottom tire. When I paint I'll put a quarter in all five holes.
http://i1296.photobucket.com/albums/...ps257433b9.jpg http://i1296.photobucket.com/albums/...ps338f9e4a.jpg http://i1296.photobucket.com/albums/...ps48c54644.jpg |
http://img203.imageshack.us/img203/1183/z5cw.jpg |
Finally got the nerve
http://i1296.photobucket.com/albums/...ps7f5ecfea.jpg http://i1296.photobucket.com/albums/...ps257433b9.jpg http://i1296.photobucket.com/albums/...pse0c52cfb.jpg http://i1296.photobucket.com/albums/...ps334461f3.jpg http://http://i1296.photobucket.com/...pse0ccf155.jpg http://i1296.photobucket.com/albums/...psdad47785.jpg http://i1296.photobucket.com/albums/...ps54be16fd.jpg http://i1296.photobucket.com/albums/...ps6614bb37.jpg http://i1296.photobucket.com/albums/...ps69dc465f.jpg I'm actually pretty proud of myself:cool: mask, 3m scratch pad, quarters in the lug holes, spray with SprayMax 2k primer, paint with REM Trim Black, wala! |
Nice job, your car looks great and the wheels just right.
I started redoing my wheels today using rattle cans. I used the paint (Metallic Matte Nickel #7277) for the pedals suggested by manichols. It appears a bit too dark. Any other suggestions? Lastly, is a clear coat or two recommended? Thanks, Gary
Robingb - did you use any type of primer? I used a light self etching primer to prep my wheels, from which the Matte Nickel shows up fairly light. Just a thought.
fuch refinish
Maybe someone with more knowledge on RS wheels than me (because I have none) can chime in but I don't think a clear coat is used. As far as primer, I used a two stage spray primer with the activation button on the bottom of the can to activate the epoxy into the primer. Worked great. Four months without a chip.
A few examples and discussion here: http://forums.pelicanparts.com/porsche-911-technical-forum/716779-fuchs-faux-anodizing-what-silver-paint.html |
I recently purchased some 8x16 from a Pelicanite and decided that now was the time to clean up my wheels and finish them off with an RSR finish...
Well, many weeks later and some frustration because I am sorta-anal, I decided to leave them as per the pictures below. I ended up redoing them several times because of rattle can paint color choices. I ended up Scotch-Briting the lip, other than that, the petals are of a satin silver finish.http://forums.pelicanparts.com/uploa...1509902886.JPG http://forums.pelicanparts.com/uploa...1509902886.JPG http://forums.pelicanparts.com/uploa...1509902886.JPG |
sweet
Sent from my Nexus 6 using Tapatalk |
I think he just used a Scotch Bright pad. And then painted the centres black.
They look great! |
