-   -   Just re finished my fuchs wheels RSR style (http://forums.pelicanparts.com/porsche-911-technical-forum/772390-just-re-finished-my-fuchs-wheels-rsr-style.html)
Bob Harriman 10-26-2013 04:36 PM
Finally got the nerve
http://i1296.photobucket.com/albums/...ps7f5ecfea.jpg
http://i1296.photobucket.com/albums/...ps257433b9.jpg
http://i1296.photobucket.com/albums/...pse0c52cfb.jpg
http://i1296.photobucket.com/albums/...ps334461f3.jpg
http://http://i1296.photobucket.com/...pse0ccf155.jpg
http://i1296.photobucket.com/albums/...psdad47785.jpg
http://i1296.photobucket.com/albums/...ps54be16fd.jpg
http://i1296.photobucket.com/albums/...ps6614bb37.jpg
http://i1296.photobucket.com/albums/...ps69dc465f.jpg
I'm actually pretty proud of myself:cool:
mask, 3m scratch pad, quarters in the lug holes, spray with SprayMax 2k primer, paint with REM Trim Black, wala!
Reiver 10-26-2013 05:13 PM
Nice job, your car looks great and the wheels just right.
robingb 02-04-2014 05:50 PM
I started redoing my wheels today using rattle cans. I used the paint (Metallic Matte Nickel #7277) for the pedals suggested by manichols. It appears a bit too dark. Any other suggestions? Lastly, is a clear coat or two recommended? Thanks, Gary
MANichols1 02-04-2014 07:12 PM
Robingb - did you use any type of primer? I used a light self etching primer to prep my wheels, from which the Matte Nickel shows up fairly light. Just a thought.
robingb 02-04-2014 08:52 PM
fuch refinish
thanks for the reply. i used a light green self etch primer. after a few coats of paint i don't think a lighter primer would have had much influence. i will paint the black tomorrow. maybe it will make the pedals look lighter. did you finish with a clear coat? if so, was it a matte clear or a gloss clear?
Bob Harriman 02-04-2014 09:12 PM
Maybe someone with more knowledge on RS wheels than me (because I have none) can chime in but I don't think a clear coat is used. As far as primer, I used a two stage spray primer with the activation button on the bottom of the can to activate the epoxy into the primer. Worked great. Four months without a chip.
joefrantz 02-04-2014 09:25 PM
Rustoleum 7271 Brilliant Silver.
A few examples and discussion here:
http://forums.pelicanparts.com/porsche-911-technical-forum/716779-fuchs-faux-anodizing-what-silver-paint.html
nene 11-05-2017 09:28 AM
I recently purchased some 8x16 from a Pelicanite and decided that now was the time to clean up my wheels and finish them off with an RSR finish...
Well, many weeks later and some frustration because I am sorta-anal, I decided to leave them as per the pictures below. I ended up redoing them several times because of rattle can paint color choices.
I ended up Scotch-Briting the lip, other than that, the petals are of a satin silver finish.http://forums.pelicanparts.com/uploa...1509902886.JPG
Flojo 11-05-2017 10:12 AM
sweet
brainz01 11-05-2017 12:57 PM
Looks good. What paint did you use for the faux anodized?
Sent from my Nexus 6 using Tapatalk
Canada Kev 11-05-2017 01:53 PM
I think he just used a Scotch Bright pad. And then painted the centres black.
They look great!
