-   -   What is this 911SC part? (http://forums.pelicanparts.com/porsche-911-technical-forum/772544-what-911sc-part.html)
CharlieWest 09-20-2013 01:52 PM
I opened up the compartment that holds the shifter linkage and found this "part" laying at the bottom. Does anyone know what it is? Cause for concern?http://forums.pelicanparts.com/uploa...1379710361.jpg
poorsha 09-20-2013 02:05 PM
If my failing memory is correct it is one part (top or bottom) of a wire connector/joiner.
porwolf 09-20-2013 02:12 PM
That is a commom Porsche 2-circuit blade type connector housing. Here is a picture of one in an original 79 SC headlight bucket:
http://forums.pelicanparts.com/uploa...1379711508.jpg
boyt911sc 09-20-2013 02:29 PM
Speedometer wires connector........
Charlie,
That plastic connector (T2i) is used to connect the speedometer wires from engine to chassis side located in the tunnel (see circuit #70). Check the tunnel area where you found it and you'll see the green & brown wires (from transmission) and 2 brown/red wires going to the dash (front).
Tony
poorsha 09-20-2013 02:31 PM
Brain still works :)
