3.0 port size
Can I tell the port size of my 1982 SC 3.0 without removing the intake?
Yessir,..if the engine is original to the car. :)
You should have the 34mm small-port version. |
High idle
Hi Patrick Thanks for the thread. Help- I installed an electromotive crank fire and have a problem with high idle. The throttle linkage sticks at the pedal, when I lowered the motor to change the pulley could I have bent the linkage? I can return the linkage at the engine. Thanks
Linkage could be hanging up on the transmission housing mount. Drivers side of transmission near the entrance to the body. Or as it goes through the engine tin.
Return spring(s) fall off? |
| All times are GMT -8. The time now is 12:52 AM. |
