Smile lubricating a Bosch distributor
1987 carrera distributor...no points, DME runs the show...
I am changing the rotor, spark plugs and spark plugs wire set.
Is this type distributor requires that I lubricate the shaft where the rotor sits with a few oil drops...I am not clear if this applies only to older porsche models or to mine as well
Old 09-21-2013, 09:03 AM
distributor lubrication
Hi Pelicans...can someone with 1987 porsche answer my question please..
Thanks!
Old 09-21-2013, 12:48 PM
Yessir,..this applies to ALL Bosch (and Marelli) distributors to help keep the weights free and the top bushing lubed up.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-21-2013, 12:49 PM
lubricating the distributor
Thanks Steve!!
Old 09-21-2013, 01:07 PM
You are quite welcome,..
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-21-2013, 01:19 PM
E Sully's Avatar
Definitely make sure the centrifugal weights are lubricated and moving freely. They make sure the rotor stays aligned as the DME changes the timing. Don't forget the dust shield to keep the cap and rotor clean. Check the up and down play in the shaft to make sure the fiber washer is still good. They are a much simpler distributor than the earlier ones.
Ed
1973.5 T
Old 09-21-2013, 02:29 PM
