-   -   Clutch Squeak Help (http://forums.pelicanparts.com/porsche-911-technical-forum/773041-clutch-squeak-help.html)
szyzygy 09-23-2013 03:32 PM
Clutch Squeak Help
My clutch pedal has developed a bad squeak. There is a little brake fluid leak. I had the clutch cable replaced about a year ago. Nothing feels wrong with the operation of the car at all, it's just embarrassingly noisy.
I cleaned out the pedal cluster area this weekend, and it seemed to quiet down a little, but now it's bad. I put some engine oil on the spring and where it connects just before this vid.
It's been pretty cold here recently - in the 40's. Might the temp have something to do with it?
It sounds like the squeak is coming from underneath the front of the car.
<iframe width="420" height="315" src="//www.youtube.com/embed/QOJtsYwhnjA" frameborder="0" allowfullscreen></iframe>
Thanks for your comments
javadog 09-23-2013 03:45 PM
Time to pull the pedal cluster out and rebuild it.
JR
redstrosekNic 09-23-2013 04:00 PM
JR
+1
Fix your brake fluid leak, then throw some bronze bushings in the cluster. Problem solved (for a long time).
Good luck!
RWebb 09-23-2013 04:06 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/450565-yet-another-boring-rgruppe-car-part-ii-suspension-3.html
szyzygy 09-23-2013 04:20 PM
ok, thanks guys, that's kinda what I was expecting. I've heard it takes the better part of a Saturday.
with respect to the fluid leak, could something like that happen if someone put DOT4 in my brake system? I never had a leak until I had the brake fluid replaced a couple of months ago.
I suppose it's possible they didn't block the brake pedal and the MC got damaged that way?
I generally trust the guys who did it, maybe that's not the cause or maybe they just goofed.
szyzygy 09-23-2013 04:26 PM
cool, thanks, reading now
