82 911SC high idle problem
Recently I changed out my heat exchanger and muffler with some SSI's and M&K exhaust, I also removed all the AC components, compressor, and backdated. I'm noticing now the car idles around 1200-1300 RPMs. What is the best way to go about adjusting the idle back down to where it should be 900-1K?
Look&test for vacuum leaks first before tweaking any mixture/idle settings.
| All times are GMT -8. The time now is 02:57 AM. |
