engine noise
1987 carrera,
I have a spark like ( tze tze tze...) on going sound at idle when engine is warm, may be it is a tapping sound...I have a stethoscope and I was wondering where should I place the rod to localize where the sound comes from? |
Move it around until the sound is the loudest
I can hear my injectors at idle, try putting your hand on them to see if it's synchronized with the sound.
Also, maybe it's a spark plug wire jumping to ground? Look at the wires on a dark nite (or run your hands all over them if you're brave :-)) to check for sparks jumping out of the wires. Chuck.H '89 TurboLookTarga, 363k miles |
| All times are GMT -8. The time now is 03:25 AM. |
