SMHemmah
hemmah's Avatar
Tach wiring - 1969
What is the blue wire with yellow strips connected to the #12 terminal? 12V?
The Black wire with purple strips is connected to the #1 terminal and the negative side of the coil. I checked the continuity back to the coil.
The brown wire is ground.
The wire diagram I have is a bit confusing.
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 09-27-2013, 02:58 AM
