Problem with nitous installation!
Help im not getting more power when i open the tap on bottle, any ideas what might be wrong? The istallation looks sloppy now but im planning on duct taping the bottle to the hood.http://forums.pelicanparts.com/uploa...1380295244.jpg
You must have the NOS line feeding into the washer filler and not the gas tank filler. Swap and see if it's any better.
Am I the only one cringing at that metal bottle sitting on the paint?!? It's like fingernails on a blackboard for me.
Chuck.H '89 TurboLookTarga, 363k miles |
If you had seen the paintjob up close you woulnt cry, the car need a paintjob!
If you paint the wheels gold, you get the same result....or better still...change over to flint ignition!
Bob |
All the NOS pics I see have the can on the inside.
Throw it in the back seat and open up the valve and your good to go! |
Your setup looks fine, I run mine just like that and the butt dyno says I increased fuel mileage and hp.
your problem is that you need to use nitrous, not nitous
you might also try this alternative installation:http://forums.pelicanparts.com/uploa...1380310013.jpg |
Well typing on a ipad is like mastrubating with a sandpaper glove, -it just doest work!:D
It does if you have the right wood.
April first already?
You may have received one from a bad batch. Mine is set up the same exact way and works perfectly fine.
Exchange it for a new one. |
NICE!! Reminded me of that story on a different sight were a guy put the NOS energy drink in the gas tank of his motorcycle! True or fake it was an amusing read!! Anybody have the link to that story, if you know the one I'm talking about?
This actually happened. |
http://forums.pelicanparts.com/uploa...1380460618.jpg |
| All times are GMT -8. The time now is 07:42 PM. |
