Windows and sunroof
I asked this question before and got some great answers. Here is a follow-up.
I can go out to my car anytime, without keys in the ignition and roll up/down the windows and open/close the sunroof. Does this mean that someone screwed with the wiring? My understanding was that the windows/sunroof would only stay active until I pulled the keys out of the ignition.
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 08-12-2002, 05:08 PM
Information Junky
island911's Avatar
My 81 sunroof works w/ the key in position 1, and the windows only work with the key in position 2 (igintion on).
(the key in position 3, would be starter motor cranking)
I wish they would stay active until I pulled the keys out of the ignition.
Old 08-12-2002, 05:13 PM
don911's Avatar
After the ignition is turned on, you can turn the ignition off, remove the key and the windows and sunroof should work until you open a door.
If you can work the windows and sunroof all the time, I would look at the door switches first. They may be bad or the little rubber boot may not be letting the pin move out. Does your dome light work? If so, the door switch is not the problem.
From Islands post, it sounds like the windows don't work the same on the SC's. Yet another improvement on the Carreras over the SCs.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 08-12-2002, 07:17 PM
dickster's Avatar
my windows work without the keys as well. but a door has to be open with the interior light activated.
Rich
'86 coupe
"there you are"
Old 08-12-2002, 09:59 PM
My dome lights only work when I turn them on manually.
Old 08-12-2002, 10:02 PM
don911's Avatar
GS,
Check your door switches. It sounds like the pin is stuck so the system thinks the doors are closed all the time. I removed the rubber boot from my car because the pin kept poking holes in new boots and sticking.
Don
Old 08-13-2002, 05:48 AM
