Retired, finally
SiberianDVM's Avatar
Brake pad sensor wire delete ??
As part of my wintertime refresh on my track car, I'd like to remove the brake pad sensor wires I no longer use. Previously I had made jumpers for each wire so the light would not come on. Now I want to remove the wires or at least make them invisible.
The fronts were easy: I just pushed the wheel well grommet into the space next to the gas tank and filled the holes with metal plugs.
The rears appear to be more challenging. I have the trailing arms removed for bushing replacement with monoballs, and the wire seems to disappear up in the nether regions under the rear seat. Does it exit inside the tunnel or is it the paired wire just above the shifter coupler plate?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 12-01-2013, 03:23 PM
