Slippery Slope Expert
Steam Driver's Avatar
Shift Lever Bearing
I'm in the process of installing a Seine shifter kit on my SC; 1982. When I disassembled the shift tower it seemed to me the lever was a REALLY tight fit in the lower carrier, called the "Shift Lever Bearing," Item #3 on the parts diagram. Examination of the "bearing" (sorry 'bout the quotes, just seems a strange terminology to me) showed that the long sides were squeezed in; curved towards the center to apply pressure on the sides of the lever where it goes through. Squeezed in enough to where there's obvious friction there that seems to me shouldn't be present.
Is this normal? It seems to me this thing should be essentially rectangular with straight sides. I've priced a new part (Pelican carries them as NLA) and they're $188 so buying one on supposition is a little pricey.
I'm thinking the best way to handle this would be to just spread the sides of the bearing "box" back to normal, or if the pinch is normal at least to relieve the pressure a little.
Old 09-28-2013, 04:25 PM
Go-Kart Mozart
JAR0023's Avatar
Seine has a good write up on blueprinting the 915 shifter. No need to buy a new part. -J
Seine Systems > Blue Printing the 915 Shift Housing
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-28-2013, 05:09 PM
Thanks. I found that item after posting the question. Need to not be so trigger-happy!
Old 09-29-2013, 06:48 AM
