adjustment of torision bars, is this the right way?
1 Attachment(s)
I have heard that when I would do an adjustment on my torision bars in the front, with just screw on this bolt that I have here on the picture.
Can anywone confirm this? Is it that simple? |
If you mean to raise and lower the front ride height, yes.
Yes, that bolt adjusts the ride height. Be sure to have the corner jacked up when you turn the bolt.
You realize, of course, you will also be changing the front wheel alignment slightly. Lowering the ride hight causes the car to ride more on the interior most tread bilaterally.;)
Thanks!!
Now another question, does anybody now how much one turn on that bolt is in mm on the body? /J |
Thats a good question Jocke... I'll see if i can't find out for you.
Eric |
| All times are GMT -8. The time now is 08:55 PM. |
