-   -   Transmission Let Go - Time to Rebuild or Replace? (http://forums.pelicanparts.com/porsche-911-technical-forum/774285-transmission-let-go-time-rebuild-replace.html)
VFR750 09-30-2013 06:09 PM
Here is my new problem:
http://forums.pelicanparts.com/uploa...1380589079.jpg
Looks like a dog tooth on the plug, plus metal shavings. :(
Lasted 32 years, 132K miles. 70-75 track days.
On the way into work, it failed on a 4-3 downshift at 60 mph, on an exit ramp. Did not lock-up, thank goodness! But it ground for a bit as I got to a safe spot. I can only shift into 2nd now. Gearshift will not go towards 3-4 gate.
Engine/Transmission will be coming out soon, and a partial teardown of the transmission. Question will be, rebuild or replace? Did I do too much damage? Time will tell...
john walker's workshop 09-30-2013 07:07 PM
usually just normal replacement parts. check the center case where the 5th/rev shift rod slides and be sure it's not dented in. happens when 1st syncro teeth break and the syncro comes out.
Peter Zimmermann 09-30-2013 07:52 PM
Welcome to Red Line Porsche Wiki - Porsche Wiki
Scroll the left side of the page, click on "915" under "page tags," the site will take you to my 9-part 915 repair Tutorial.
VFR750 10-01-2013 03:03 AM
Thanks guys. I'll will be reading your guide.
VFR750 10-06-2013 11:21 AM
Peter,
Your guide is very good. I also like your section on what to use and what to replace. Sticker shock did set in. But after chewing on it for the week, $2500+ in parts, amortized over the future 15-20 years of use, makes it seem like a good investment.
The biggest hurdle is getting used to the idea that the car will be out of service for a long time. For me, this is the time to tackle the rebuild the engine; 3-5 years of work, at least. Once I got my head around the time and cost, it seems like the right thing to do.
Just going to miss driving the car for a long time....
