DGriz's Avatar
Crazy Oil Pressue Gauge below 1500 RPM. Solution?
The oil pressure gauge on my SC fluctuates wildly between 0 and 5 when at idle up until 1500 RPMs...Where it then sticks at 5 while driving...
Bad gauge or pressure sensor? Something I could replace myself?
Thanks! Dickson
Capitalist Pig
1979 911 Targa "Smokey"
1983 944 Track Car
Old 10-01-2013, 05:42 PM
theiceman's Avatar
its fairly easy if you dont have ac to replace the sender. it is the cylindical sensor to the right of the fan when facing the engine. a word of caution though, remove the sensor and block it is screwed into as one piece,then remove the sensor from the block in a vice and replace.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-01-2013, 06:11 PM
Capitalist and Patriot
911Freak's Avatar
Could just be a loose wire at sender
Old 10-01-2013, 07:19 PM
fred cook's Avatar
Sender
Most likely the sender is bad. theiceman gives good advice for removing the old sender. Failing to do it this way can cause you to destroy the engine block!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
bauerjy
Guest
Posts: n/a
Clean the contacts
Try cleaning the contacts with sandpaper or CocaCola - worked for me.
Old 10-01-2013, 07:34 PM
DGriz's Avatar
Thanks. The car does have AC, but I'll do my best.
Capitalist Pig
1983 944 Track Car
Old 10-02-2013, 09:08 AM
