-   -   Measure oil temp using meat temp gauge (http://forums.pelicanparts.com/porsche-911-technical-forum/774617-measure-oil-temp-using-meat-temp-gauge.html)
hemmah 10-02-2013 04:06 PM
Am I incorrect with my assumption that the best way to measure oil temp is with a meat temperature gauge in the hot oil down the oil add tube??
Assumption contributors:
Oil pressure is fast in an early engine. What is the oil pressure at 1000RPM, warm in a early Porsche engine? Around 20 PSI?
I don't have oil coolers on the front of the car - just the original oil cooler at the back of the engine. The distance from the hot engine parts and holding tank is short.
My meat temperature sensor is long and I know it is in hot oil as it sensor end is longer than my dip stick.
Opinions Please
hemmah 10-03-2013 10:49 AM
bump
ClickClickBoom 10-03-2013 11:16 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/736256-3-2-operating-temp.html
A 2.7 will need an additional cooler, fender or otherwise, but you will need it if you drive remotely hard.
http://forums.pelicanparts.com/porsche-911-technical-forum/469988-oil-temps.html
http://forums.pelicanparts.com/porsche-911-technical-forum/482806-oil-cooler-details.html
Craig 10-03-2013 12:16 PM
Steve,
I think a thermometer would work just fine, just don't drop it in the tank!
I did almost the same thing with my MG, except I used the thermometer in the radiator to test water temp.
Or you could get an infrared temp gun and test that way. SmileWavy
Craig
dan88911 10-03-2013 01:50 PM
This outfit makes an oil temp/gauge replacement for the dip stick.
Mainely Custom by Design - Engine Component products
