JeffO's Avatar
Installed M K exhaust, clamp question
Installed the one in one out muffler to a previously installed M K premuffler and I have a question concerning the spring loaded band clamps. Just how tight do you make the clamp? I tightned till about one inch of the thread came past the lock nut and feel the the system is very solid against the bracket but also know there is more to go if the spring is to bottom out. I stopped at about the midpoint of first complete contact of the clamp and half way of the screw. Thanks for any insight.
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 10-03-2013, 03:16 AM
cycling has-been
bkreigsr's Avatar
I tighten mine fully compressing the spring, then back off 3-4 full turns. - just to be sure that the strap conforms to the shape of the hangers on the engine side.
- a 1/4in drive, 11 mm deep-well socket, is your best friend here.
Bill K
Old 10-03-2013, 05:01 AM
JeffO's Avatar
thank you Bill
1988 911 coupe
2008 VW R32
2004 530I
Old 10-03-2013, 05:46 AM
