Early car cold start problem
Hello...Lately, my 69S has been hard to start cold. There are 2 sending units on the breather cover. The one closest to the back of the car,with a yellow wire, I think is the culprit. There is power to the sender. Question is, what does that sending unit do?
The engine cranks and cranks for quite a long time before it starts, and I have tried all kinds of combinations of hand throttle and gas pedal.
Am I on the right track? Anything else to check?
Early S Man????
TIA
Old 08-14-2002, 09:55 AM
Friend of Warren
Do you still have MFI? If so sounds like you have either lost power to your cold start enrichment solenoid or the enrichment solenoid has gone bad.
Kurt V
Old 08-14-2002, 10:03 AM
Early_S_Man's Avatar
Porsche Crest
Mike,
The cold-start circuit on the '69 911E and 911S models is a bit more complicated than 1970 and later models!
The two-pole 'sender' with the 'G' and 'W' terminals is called a 'Thermo-Time Switch' ... and there are two of them!
The Yellow wire is the same as the #50 starter solenoid lead from the ignition switch, and goes to the 'G' terminal, which is a heating element with about 25 Ohms resistance to ground, the body of the sender. The Yellow wire is 'multipled' over to the 'start assist' switch.
The Red/Black or Red wire goes to terminal 'W' and is the switch contact. When the switch body is below about 112°F, the switch contact should be closed to ground. The Thermo-Time Switches can be removed from the breather cover, and tested in a pan of water on a hotplate.
The Key below refers to Device numbers on the schematic that are numbers inside circles adjacent to the item. The devices of interest in the cold-start circuit are #68 Cold-start Solenoid, #66 & #67relays, #70 Time-Limit Switch, and #71 & #72 Thermo-Time Switches.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-14-2002, 10:56 AM
Friend of Warren
Originally posted by Early_S_Man
Mike,
Mike, Warren is correct. I just know enough to be dangerous!
Kurt V
Old 08-14-2002, 01:03 PM
