MN
Looking for a Fresh Air Blower Knob (Black)
Hi,
Does anyone have a Fresh Air Blower black knob I could buy from them OR do they know where I could buy one that is in stock?? Thank you, Sarah
87 930 Blk/Blk |
Friend of Warren
I need the exact same knob! So anyone know where there might be two of them?
Kurt V No more Porsches, but a revolving number of motorcycles. |
I have several, get me an address and it's yours.
2000 MR2 spyder 2001 ford Escape |
and kurt, I have one for you too.
MN
That is so cool!! Thank you so much! I'll send you a pm with my address.
87 930 Blk/Blk |
Maybe you guys would know. Is it possible to get fresh air through the louvered vents in the dash, the ones the A/C uses? I can get air on my feet or my windshield, but not my face.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Friend of Warren
F2P you da man! Just sent u a PM with my address. Sarah, thanks for this post which reminded me that I needed that knob too. And JGordon, I feel your pain, but it can't be done. Two separte systems. What I normally do is set the fresh air split between defrost and feet and just turn on the AC knob to blow some air towards my face. My AC isn't even hooked up.
MN
Hey Kurt - The missing knob has been bugging me for a long time. I tried to get one from our p-techs but it was taking soooo loooong I had to take matters into my own hands!!
![]() Thanks to F2P, my knob search ended today!! YEA!! Jgordon - I also can't really get much fresh air right on me. The A/C is kinda noisy, so what I usually end-up doing is putting the windows mostly down and open the sunroof. It seems to pull the most cool air in. (The inside of our 930 is black so it can feel like a sauna in there). Have a good day guys!!
87 930 Blk/Blk |
i just bought one through pelican. it is listed on the receipt as "heater knob, black" but its the fresh air knob. the part number was 911-613-139-0001 C and cost $2.20 and its a perfect fit.
1987 Carrera Targa |
MN
Z - I had checked the categories on Pelcian Products but could not find it listed. Guess you had better luck then I did. Thanks for the info anyway.
87 930 Blk/Blk |
Sarah and all--use some suprglue on those little buggers. I've had them loose on two Porsches and the only way I found to keep them from cracking and loosening was to use some glue.
george 86Targa "Jessie" Eternity is long, especially near the end! |
Hi, Sarah and Kurt, what you wanna use for the absolute best bond is "LOCTITE 414" if you can find it.. super glue is fine too but it will eventually degrade and fracture the bond line.
Just a little advice... no biggy Jorge (Targa Dude)
MN
Thanks for everybody's help/advise with this.
87 930 Blk/Blk |
"Z - I had checked the categories on Pelcian Products but could not find it listed. Guess you had better luck then I did. Thanks for the info anyway."
i couldn't find the parts listed either...so i called their 800 number and the customer rep located the number for me.
