1977 911S
Carrera Chain Tensioner Upgrade
Can anyone tell if this car has the Carrera Chain Tensioner Upgrade from this picture?
Thanks in advance!
Old 10-08-2013, 08:59 PM
The telltale oil lines are blocked pretty effectively in this picture, but I'm pretty sure I see one on the lower right on the passenger-side cam cover. So I'm going to go with "Yes".
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 10-08-2013, 09:04 PM
Show the chain covers.......
Spencer,
Post another picture of the engine showing the chain covers. The picture you posted does not show the areas where the Carrera chain tensiner oil lines are located.
Tony
Old 10-08-2013, 09:06 PM
Go-Kart Mozart
JAR0023's Avatar
I think I see one of the small liens under the nose of the A/C compressor in your photo.
Look at the two photos below. The small lines that "T" off the cam oil lines and snake down the front of the chain covers are the lines that feed oil to the Carrera tensioners. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 10-08-2013, 09:07 PM
1977 911S
Unfortunately that is the only picture I have.
Old 10-09-2013, 09:13 AM
Carrera chain tensioners.......
Spence,
I missed the little oil under the AC bracket in the picture you posted. Like most people with better eyes, saw it as an upgrade version. I would concur with their observation too. The engine you posted has been upgraded to hydraulic fed Carrera tensioners.
Tony
Old 10-09-2013, 09:20 AM
1977 911S
Thanks everyone. The car is an hour drive away and I'm seeing it again and want to go with as much information as possible.
Old 10-09-2013, 09:39 AM
non-whiner
mreid's Avatar
You definitely have it on the passenger side! Can't see the driver side.
"Too much is just enough."
Old 10-09-2013, 04:45 PM
