wolds's Avatar
I think it's time for a fuel pump
I've owned the car since August of last year and thought it would be a good idea to replace my 30 year old pump over the winter, so I got the car up on stands yesterday and pulled the protective plate. Look what I found. A nice little time bomb just waiting to go off. It wasn't leaking bad enough to drip on the floor, but the piece of foam between the pump and the plate was soaked. Additionally the two mounting points for the pump were both broken so all that was supporting the pump were the hoses. The takeaway from this was, Check your pumps if you haven't, this could have been bad. Warren
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 12-24-2013, 03:24 AM
911SC Tinkerer
merlinfe's Avatar
You're very lucky you checked that out when you did.
You may want to play the lottery tonight.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 12-24-2013, 04:24 AM
Preventive maintenance.....
Warren,
Good finding the condition of your main fuel delivery system before any problem develops. This would be a good time to replace old and brittle fuel lines. Len Cummings (BoxsterGT) has replacement fuel lines comparable to OEM lines if you decide the need to replace some of your outdated fuel lines.
Merry X'mas to all and say hello to Beth.
Tony
Old 12-24-2013, 04:35 AM
wolds's Avatar
Tony,
I'll be checking and/or replacing the lines as well. I was under the car to change M&T mounts along with stabilizer links and bushings. See you in Hershey? Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 12-24-2013, 04:48 AM
KBOUSTANI's Avatar
mine died last week and had to tow my car to the mechanic.
check and replace if yours is old.
76 carrera 3.0 SSI W/M&K 1RARE76/]89 carrera 4 (964)SOLD
87 targa 3.2,fabspeed cat bypass,sw chip,m&k exhaust(sold)94 carrera 2 cabriolet(sold)00 carrera 996(sold)
95 993,red,meanest looking one(sold)
83 911 sc targa,my first porsche(sold)
Old 12-24-2013, 12:08 PM
wolds's Avatar
Can anyone tell me if there is supposed to be a small piece of foam between the fuel pump and the steel pan that covers it and the steering rack? Mine had one, but I don't see the purpose of it nor do I see it in PET. It appears that mine was soaking up water and contributed to the corrosion that you see on the picture of the pump that I posted above. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-03-2014, 09:13 AM
I have a fuel pump available if you are interested.
1982 911 Targa, 3.0L ROW with Webers
Old 01-03-2014, 09:40 AM
wolds's Avatar
I already picked one up, but thanks for the offer. Any thoughts on the foam question? Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-03-2014, 10:56 AM
I just took mine out over last weekend and did not see any foam. Seems like a bad place for something that would soak up water.
Old 01-03-2014, 11:00 AM
wolds's Avatar
I'm thinking that someone added the foam to keep the pump from rattling on the cover due to the broken mounts. I'm guessing that this caused the majority of the corrosion. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-03-2014, 11:08 AM
dshepp806's Avatar
I found a piece there when I changed out my original pump (on a 89).
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-03-2014, 12:30 PM
Sugar Scoops Rule :)
dave 911's Avatar
Dang, good call on checking it when you did.
That looks like an artifact from the Titanic
Or like the master cylinder that I pulled off my 62 VW last year
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 01-03-2014, 12:36 PM
KNS KNS is offline
You could use closed cell foam in its place which would not hold water
Old 01-03-2014, 03:01 PM
wolds's Avatar
That's a thought although if it doesn't contact the cover I don't see the point of adding it. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-04-2014, 05:53 AM
Fuel pump.......
Warren,
Do you have the FP bracket on rubber mount? If not, I would place a strip of rubber material between the FP and the metal band. I've never seen a CIS FP wrapped with insulation foam. As a matter of fact, the FP should be exposed to air flow for additional cooling (fuel flow acts as coolant).
Tony
Old 01-04-2014, 07:30 AM
wolds's Avatar
Tony,
I have ordered a new mount along with the rubber isolators and the band clamp. The old pump wasn't wrapped in foam, just painted black. The foam in question was a rectangular piece sandwiched between the pump and plate which as I said in my last post doesn't make sense to me as I would expect an air gap between the plate and pump for air circulation. Warren
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 01-04-2014, 08:29 AM
