SWB shocks - Koni`s
So, I was thinking about why the strut towers had been extended and how low the back of the car was so I went and had another look at the Koni`s that were installed at the rear.
They are Koni 8210-1159 adjustable shocks.
I`m guessing that now Ive had the struts put back to standard these wont fit my SWB car?
Picture of the strut extensions on my SWB ( now returned to standard )
As they are now
And pictures of the shocks
Will they still fit? And if so, what size torsion bar should I use?
Old 10-10-2013, 08:36 PM
Under the radar
Trackrash's Avatar
This is a hard question to answer. You will probably have to test the fit. My opinion is the 8210-1159 will be too long if you bring the towers back to stock.
Compare the 8210-1159 with the Koni red from my '71. Additionally the bolt holes are 14mm on the 8210-1159 and 12mm on the reds.
EDIT: BTW The correct Koni yellow has been out of production for many years, Paragon and some other catalogs will list 8210-1159 as correct for the older cars, however.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-10-2013, 09:09 PM
Thanks for the advice Gordon.. I`m keen to see what the SWB front shocks are now. I do have LWB suspension to go in the front though.
If the rears do fit though it will alter my plans for the front shocks.
Old 10-11-2013, 12:57 AM
