Need Offset for 17X8 and 17X10s
What is the correct offset to fit 17X8 and 17X10s on an SC and on a 964? I know the SC and 964 have different offsets but I want to know both.
Thanks |
you cant put the m on the sc the oil line and trailing arm bolt are in the way in the rear, 9.5 is max most do 9, the c2 should be 52 all the way around, Kevin
I plan on moving the oil lines and grinding the trailing arm bolt, so the question is, after I do this, what is the offset for 17X8 and 17 X 10s? I know Jack Olsen did it.
Ask Jack
Hi, I'm Jack.
And the answer is: I don't know. I mounted tires on the things right away (they got here two days before a 7-day track event), so I didn't get a chance to measure them. But if you're getting the wheels from Lindsey Racing, then shoot me an email, and I can help coordinate your getting the same dimensions I got from them for your set. Otherwise, remind me early next week -- when I swap on the just arrived 8x9x17 street versions, I'll take some measurements from the track set. |
| All times are GMT -8. The time now is 12:10 AM. |
