-   -   To Port or not to Port? (http://forums.pelicanparts.com/porsche-911-technical-forum/77611-port-not-port.html)
ericleach 08-15-2002 09:43 AM
Okay I have a 2.4L (73') engine that originally was a "T", but Im upgrading the motor with "S" pistons and Solex cams. The heads are still "T" heads, should I port them out to "S" size or should I leave them alone. Any thoughts would be great, seeing how I dont want to waste the money or be dissapointed.
Thanks Eric
HawgRyder 08-15-2002 11:35 AM
Any porting would be OK if you're going to increase the size of the valves at the same time.
If not...the money spent on porting would be better spent on a good exhaust system.
Remember...what goes in must come out!
Bob
ericleach 08-15-2002 11:40 AM
Vlave sizes are going to stay the same.
The guy who wants to port the heads said Im probably losing a lot of bottom end power.
Eric
Early_S_Man 08-15-2002 12:42 PM
Eric,
That disclaimer sounds like a 'warning' light to me! The Solex cams are only slightly 'hotter' than the 2.4E cams ... and the 'E' ports were only 32 mm. What are your ports now? 30 mm or 32 mm?
If your 'porting' guy is suggesting going to 36 mm 'S-spec' ports ... that would be a mistake with Solex cams! Use 'S' cams with 'S' ports, and 'E' ports with Solex/'E' cams! You can even use 'S' cams with 'T' ports ... for more torque across the rev range, and only about 10 hp loss at the top end over an 'S' engine! The type 901/30 rally engine did just that with carbs in 1968!
ps ... Hawg
ALL 2.2, 2.4, 2.7 engines used the SAME 46 mm/40 mm valve sizes!!!
jpachard 08-15-2002 01:29 PM
Depends on the Vintage. I personally like the Sandeman's 20 Yr.
Cheers, James
Chuck Moreland 08-15-2002 01:45 PM
T, E and S have the same size valves. Only the port sizes are different.
But as Warren says, don't mismatch the cam. Port to the proper size for the cam, no bigger.
Why not go for the S cam?
J P Stein 08-15-2002 02:00 PM
Assuming that you have 2.4L heads, port em'.......34 or 35 mm would be good, me thinks.
Solex cams love to rev.
Tho they have a very similar profile compared to the E cams, their lobe centers are the same as the S cams. .....lots of overlap (over 4mm) for scavenging at elevated rpms......in practice.
Making them run smoothly at low revs is....or was, my biggest problem. The 35mm ports on my 2.7 (smoothed out to a bit over, actually) probably didn't help here, but it pulls hard from 4k to over 7k. Driveability is good down to 2500 or so.
According to my research (while building this motor), the combo of S cams and Webers bring another set of problems.
Want low end? Go with T cams & leave the ports alone.....but that's no fun:D
