Anybody use crane cams??
Has anybody used crane cams before??? A friend of mine gave me a set for my 930 as a bday present. The set he got me are the mid range cams, the specs are:
Degrees Duration @ 1mm Int./Exh. Degrees 262/244
Degrees Advertised Duration Int./Exh. 296/278
Degree Lobe Separation 102
Lift Int./Exh. 12.09mm (.476)/11.28mm (.444)
Any feedback, they seem like they would be a top end cam like a "S", they are advertised as 3k-6.5k
Thanks. tom
Old 08-15-2002, 11:03 AM
