-   -   Mouse damage! (http://forums.pelicanparts.com/porsche-911-technical-forum/7764-mouse-damage.html)
david w. 08-29-2001 05:10 PM
Mouse damage!
I just began digging into my new project car, a 73 911 coupe.
I removed the drivers side floor board to expose the pedal cluster and found a wire harness (about 3/4" round) with several wires chewed, and damaged by mice.
About 7 wires are destroyed in this area.
My question is, should I splice new wires in? Or replace the entire harness?
I will also need to know if this is the main harness? or what it is called. (to find a new one.)
Thanks.
john walker's workshop 08-29-2001 05:51 PM
expose the wiring by slitting the harness, replace one section of wire at a time (match the colors) solder them and use heat shrink tubing to insulate. then tape up the harness. nothing wrong with a proper repair job. wire crimps in a harness are not the best way to fix it.
david w. 08-29-2001 05:58 PM
I will attempt to solder them this weekend-thanks for your advice.
derkpitt 08-29-2001 06:18 PM
In aviation we use wire crimps all the time. It's better than soldering and faster. Just make sure your using AMP type splices, with the right tooling. Not the cheap automotive type. Do you know any Aircraft mechanics?
Derk Pitt
88 Carrera Coupe
Kurt B 08-29-2001 08:42 PM
my experience is that crimps tend to pull, but I've used both. Of course, crimps done right don't pull as often. I would recommend in this case soldering anyway and shrink wrapping around it. It will look the most professional to the next owner who will no doubt view yor handiwork.
Joeaksa 08-30-2001 04:24 AM
David,
If you have had a mouse in one part of the car, you may have had more in other areas.
Check the pic out on my website and you will see what a mouse cost me. Worth taking a flashlight and looking just in case!
Joe
http://pws.prserv.net/usinet.joeaksa/porsche1.htm
rstoll 08-30-2001 04:45 AM
Hey Joe, I hear your Rat damage could have been prevented by Mobil 1. http://www.pelicanparts.com/ultimate/smile.gif
Robert Stoll
83 SC
83 944
Joeaksa 08-30-2001 05:31 AM
Robert,
You are totally correct, however it was a mouse! You hold the critter and I will dunk it in Mobil One (or Castrol for that matter), then we can both light the match... and stand back!
Since its your idea, lets try it on your car first!
Joe
Joeaksa 08-30-2001 05:36 AM
Robert,
Forgot, if anyone runs out of Rogane, Mobil One works well in this area as well! I have tried it for years and while I am still bald, the fuzz keeps growing enough to make me go to a barber every couple of weeks.
Spread the word!
JA
rstoll 08-30-2001 08:39 AM
Let's see now.....WD-40 for my arthritic knee and Mobil 1 for my bald spot. Got it!
Robert Stoll
83 SC
83 944
david w. 08-30-2001 09:31 AM
How do the little bastards digest copper?
Saffs 08-30-2001 09:48 AM
I had a mouse in my old '81 BMW M535i. As well as eating some wires it ate the MOT certificate (UK certificate equiv. to US inspection) and my insurance papers for it that I'd stupidly left under the seat - only left the car in airport parking for 3 weeks.
If I got stopped by the Police I was prepared to say a mouse ate my docs....
'75 911S Targa
'81 BMW Alpina C1 2.3
rstoll 08-30-2001 10:09 AM
I think their tiny system can process a Brillo pad.
Robert Stoll
83 SC
83 944
Joeaksa 08-30-2001 12:37 PM
David,
They do not eat the wire, they love the insulation around the wire. Course the whole matter is made worse by the droppings they leave, as the area is now filled with mouse crap and where ever they pee it stinks and does wonders for the metal.
Robert, its VIAGRA for your knee... http://www.pelicanparts.com/ultimate/smile.gif
Joe
Joeaksa 08-30-2001 12:39 PM
David,
Also, was at a shop two weeks ago and they were getting ready to crush a 911 that was terminal. I took all the wiring harness out that I could get to easily. Try to find a wrecked car and get the harness, that way the wires you splice into the harness are the right color code and size!
Joe
rstoll 08-30-2001 02:54 PM
Is the main ingredient in Viagra really Micoxaphloppin???? http://www.pelicanparts.com/ultimate/smile.gif
Robert Stoll
83 SC
83 944
david w. 08-30-2001 06:41 PM
Wow -crush a 911? NO!
Tommorow?- I solder! I will splice the wires and use heat shrink.
I will also use Decon rat pellets, Swiss cheese and a good old mouse trap!
I will let you know what I catch!
david w. 09-01-2001 04:22 PM
Well, I spent 4 hours on my back today with a hot droplight next to my face, and the fumes from the hot soldering gun in front of my nose.
I found that the little RAT lived in the tunnel. He had newspaper, hay,and all kinds of sh-t in there.
I cleaned it out, soldered, and heat shrinked!
Alot of work, but I really enjoyed it..
Doug Zielke 09-01-2001 06:26 PM
I can loan out one of the "girls"....
http://www.pelicanparts.com/ultimate...loads/catz.JPG
The Lynx-Siamese are especially tough on rodents! (Or anything else that moves.)
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
[This message has been edited by Doug Zielke (edited 09-02-2001).]
