Free minder
Do you feel like your car feels ?
Friends,
I don`t really know why I am writing this, just want to share a piece of life with my Porsche, and see if anyone can relate to that. I am kind of feeling down ![]() which screwed my right caster angle by putting the right wheel 1/4 inch shorter than the left one after it hit the road border..that is about it. I can still consider I got lucky, after the big tree that fell in my garden during the last strom did not hit the P-car ![]() ![]() Aurel 78 SC Targa |
Aurel, it sure looks good anyway
![]() I guess the broken headstuds is just the risk we take owning older cars. Get those things fixed it it will be back to it's former glory for sure. |
Hilbilly Deluxe
Look at it this way, you have the oportunity to refresh the top end and replace the cams. You can fix the oil leak while you have the engine out, even clean up the pistons and re-ring if you find the need. You can also swap in some higher compression pistons if you want, or depending on what is legal where you live, junk the CIS altogether and go to Webers, (with a much more agressive cam, and pistons to match). 250 HP is closer than you think.
![]() Not sure I get what you are saying about the caster problem. ¼" seems like a lot of difference, have you put it on a rack to see if something is bent? I hope you mean broken head studs. Never heard of pulled on an aluminum case. broken=lower machine shop bill and you don't need to split the case. Nice looking car, What color is that? Tom |
Free minder
Just what I wanted to hear ! Thanks buddy. I am not sure I will go to 250 Hp, but a top end refresh could be a nice project. The greatest problem is that I have no garage to do the work though. One solution would be to drop the engine by a nice day, and put it in the basement till next spring...I wonder if two persons can carry that easily. But I`ll fix the targa top and the alignment first. Color is dark metallic green, I don`t know how it is exactly called. British ? For the headstuds, you`re right, they are broken, not pulled. I was typing wihtout thinking.eek:
Aurel ![]() |
Senior Member
Things could be worse. You could be a starving African girl with AIDS (sorry to be so graphic, but sometimes we miss the broader picture). I thoroughly enjoyed my rebuild this last Winter and you will too. If two guys are going to carry the engine down the stairs, I'd suggest stripping the intake, exhaust and tranny, and use big guys. No problem. Sometimes we need to put our car up on blocks and refresh them. They are getting older, but you can reverse that. When you're done, you'll probably be prouder of your car than you ever were before, particularly if you do the engine disassembly/assembly. Xterra's probably an excellent winter car. This is more of an opportunity than a problem, it seems to me.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Free minder
You`re right superman, things could be worse. But it is all a matter of perception, as you know. I guess we all come to earth with different challenges and lessons to learn. Some have to be happy with aids and starvation, others with broken heads studs !
That seems really unjust, and we could think that God was more cruel to some than others. But the spiritual justification is that all the things we go through are a choice we made ourselves, before we were born. Of course, this implies to beleive in reincarnation, and look at the body as just a temporary vehicle for the soul... To go back to the car, I am still hesitant to do the engine drop this winter, because besides the oil leak, it runs very strong, starts immediatly, idles perfectly...how was yours before you rebuilt it ? And did you feel a difference after that ? I`ve got 101 Kmiles on the clock. Aurel |
Bandwidth AbUser
Yeah, the broken door pocket would have me bummed...
LOL
Jim R. |
Do you feel like we do?
Bandwidth AbUser
Dood, I feel a lot better now!
LOL
Jim R. |
I was in a similar boat as you. I found 2 broken head studs this spring when I was adjusting the valves. I sucked it up and pulled the engine, replaced all the lower dilivar studs with steel ones, new gaskets and I was back on the road in two weeks for about $300 bucks.
The car ran great before so I opted not to rebuild the engine. My engine had 107,000 miles on it at the time. ![]()
John Adams 1980 ROW 911SC |
![]() Quote:
What would have happened had you not discovered the broken head studs John? Did you notice any difference after renewing them? Still, terrific that you were able to tackle this yourself - I doubt I'd have the courage. Maybe after Wayne's new engine re-build book.
Cheers, Sean. 94 911 Carrera 2 993 Cab http://www.pelicanparts.com/gallery/Sean_Hamilton |
Senior Member
Three cheers for John! Many people dream of going in, replacing a few studs and some gaskets and being back on the road in 2 weeks for $300, but all seem to succumb to the "while I'm in there..." sickness. Hooray for John!
I don't think anything in this life really matters except our choices once we're here, and the kind of creature we make ourselves into as a result. In that sense, the unlucky ones are really the lucky ones, and vice versa. Having gotten away with my shocking remark above (thank you for your tolerance), I can further illustrate the same principle by reporting that last night I reflected on how irritated I sometimes get when my child parks her bicycle right outside the back door, and what a terrible walking obstacle that becomes. I thanked the Big Guy for problems like these. Now, back to Porsches... My car ran great before the rebuild. I had between 190 and 195 psi compression on all cylinders. A car that could make anyone smile. But now the heads are freshened, new rings and 20/21 cams. It is even more fun to drive now. Mine had 182K miles. Your decision is not a no-brainer. Good luck.
Sean Hamilton
I had no symtoms of any kind before I replaced the studs. No discernable change afterwards. But great peace of mind!
