Speedometer. HELP
The other day my speedometer needle started to get twitchy, erratic, then it just died and the the odometer s failed as well.
So is it electrical or gauge gear wheels worn out. |
Sounds like it isn't getting a signal (electrical) easy enough to pull out the speedo and check the connections.
I just had to have mine repaired because of worn gears, odometer quit but speedo kept working. |
What year is it? Based off what you said the wires may be coming loose off the sending unit on the transaxle. But it could also be a speedo cable that broke, depending on the year of the car.
What year and model do you have?
Could be a bad speedo cable, bad sender, wiring issues, gauge needs service, etc.. |
I've done two 74 speedos and am betting on cable coming unplugged or breaking. Mine were odo not turning but speedo was fine.
74 911 |
| All times are GMT -8. The time now is 02:46 AM. |
