Ignition Help Revisited
Trying to figure out what is going on here. I have two cars both with 3.0 SC motors stock ignition systems. First I swapped the coil from the running car into the non running car. Non dice. Then I swap in the CDI and it fire up no problem at all. So, I thought I had a bad CDI. I Sent the CDI to Pelican for a rebuild / repair and they call me and say its fine and charge $20 for the inspection and guarantee the CDI will be good for a year. Put the inspected CDI and coil from the formally non running car into the donor car. Donor now wont start. Figure I must have made a mistake and my weak memory played tricks on me and I had swapped the CDI first so I need a new coil. New coil in still no spark no start. I'll swap back in the CDI from the running car later on today, but is there a way to check these things at home? What should I say to the folks at Pelican Refund me for the coil I did not need and fix the CDI assuming the swap works which I suspect it will
Old 10-19-2013, 08:16 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
When I run into a problem like this...I make a paper chart and tag (sticker) each part so they don't get mixed up.
Logic says...if you find a combination of CDI and coil that works one one engine....try that package on the other engine.
If it works...you have a base line for experimentation.
Gets easy from there.
Also...are you sure both coils are CDI type coils?
It's easy to mix up parts if they all look the same.
Bob
Bob Hutson
Old 10-19-2013, 11:08 AM
